Mazda RX-8 Instrument cluster swap(no CAN)
PermDude
Post by PermDude »
Hello i from Poland and i have a question :lol:
I going to swap instrument cluster RX-8 for my car. But the car dont have CAN-Bus.
How to convert analog signals with sensor to can-bus for RX-8 standard?
In the topic admin create converter, how?
Source here is, but dont have wiring diagram.
http://rusefi.com/forum/viewtopic.php?f=4&t=759
Re: Mazda RX-8 Instrument cluster swap(no CAN)
Hello!
On the one hand rusEfi can do this, but you would have to do a lot of reading to get it going - there is no step by step instruction for your use case.
PermDude
Post by PermDude »
I understand, more reading.
I found all ID CAN to RX-8 cluster. I can not write programs :D maybe time have to learn.
Respect to you :) You spent a lot of time to work the cluster :)
I need:
Arduino and MCP2515 only? and more info how to write arduino?
My car have only analog sensor.
All my sensor have resistance, fuel level, water temperature, oil temperature etc. Speed signal is pulser. :)
Thank you for reply :)
