2003 Opel Vectra: Z20NET and derivate engines discussion
- donator
Hi i am starting this thread on russians request. Everyone having this little bit rare but powerfull engine is welcome in this thread.
Re: Z20NET and derivate engines discussion
In US second generation Saab 9-3, the one with B207 Ecotec engine is often cheap because key fobs die and this kills the car since immobilizer works with ECU. On the other hands looks like there are www.lostsaabkeys.com who seem to have a solution even if you do not have any keys.
Also I am surprised that in junk yards people have picked all 9-3 ECUs - which tells me that there is a use for those, I am curious what is the use and if that maybe has something to do with the immobilizer issue which is killing these cars?
So how close is your electrical system to these saabs, like for example how many key fobs do you have and what is your plan?
- donator
Hi,
i have 2 keyfobs, but the Saab ones look like the Mercedes ones ive seen. GM (for my model years) use classic Key fobs this type
Problem is that the trionic 8 is connected via CAN to car electronics. GM uses totally different modules as Saab also the trionic firmware is different between Saab and GM. I dont know Saabs, but GM uses RF battery operated Remotes with separate wound antenna and Immo IC. I can make photos of the inside. Reading is done in CIM module wich is a module underneath steering wheel where the stalks go, horn, steering keys, it also operates steering lock when A/T is installed. This module is connected via CAN and also acts as a gateway/filter/passtrhu/ to isolate engine CAN from body/interrior/radio/dooor/etc CAN. GM uses 3 CANs in my car. 2 separate differencial ones and one single wire.
On these Vectras i didnt heard of this type of problem. You can let GM generate you security access key to CIM or read it out from memory and tech in new immo tokens.
I heard of problem from Saab fans, that also Radios/Nav systems are problematical to install from other car as they are married with some generated keys together.
GM has lets call it "bug" in entertainment system (i dont know if it is derivated from saabs or not) where you also need to marry Nav/with LCD and CIM, but if you install one married from other car, then marry/unmarry it with donor cars key, it will reprogram and then you can marry it with you cars key even when it was not removed and propertly uninstalled on donors car. (In saabs i think this is not possible - saab owners with propper knowledge please write...)
btw here is some interresting "hot" topic for the Saab immo problem https://www.trionictuning.com/forum/viewtopic.php?f=35&t=4123&start=60
Re: Removing immobiliser system on T8. Done?
#60
Post by myrtilos » Tue Apr 03, 2018 5:56 pm
Hi! To update about that topic, we now have a working bin (thank james for the tests!) which allow the car to be started using the key and which doesn't log any error. That bin works without checking SCL / CIM so it's perfect for a stand alone ECU.
The main part of the hack consists in stop reading the key position (which is encrypted using the car immo values) and always suppose it's on position "ON". The consequence is that we can't stop the engine immediatly and the engine will continue running until we are out of fuel (a few seconds after the fuel pump is turned off).
I am working on a work around to allow the ECU to stop the engine a clean way. Here's what i have in mind :
> If vehicule speed is ZERO and if we press 3 times the brake pedal, this will turn the engine off.
It's the best option I found for now and i am working on the development, but let me know if someone here has a better idea ! If we had useless external sensor/input, then we could use it to replace the ON/OFF feature of the key, but as far as i am concerned i don't know what value could be used... Maybe AC ON/OFF if the target car doesn't have an AC this could do the trick easily...
great info, thank you!nighthunter wrote: ↑Wed Dec 12, 2018 7:54 pmbtw here is some interresting "hot" topic for the Saab immo problem https://www.trionictuning.com/forum/viewtopic.php?f=35&t=4123&start=60
I've looked at a 2006 2.0T 9-3 manual with 180K miles for sale for $550 today but the interior was too depressing or maybe I was not in the right mood, I think I should pass on this one and just wait for MORE, way MORE of your videos and focus on the software work instead
