Can the uaEFI control a LSU 4.2 wideband sensor?
trent4
Post by trent4 »
I see that it has an onboard LSU 4.9 wideband controller. Can this same controller control an LSU 4.2 sensor?
Thanks!
Re: Can the uaEFI control a LSU 4.2 wideband sensor?
It depends on what exactly are you asking. Please ask a more specific question.
RuMoDK
Post by RuMoDK »
AndreyB wrote:
Wed Feb 14, 2024 4:28 am
I'd think he's asking, if you can use a 4.2 with the UA
As is uaEFU supports only 4.9
Someone with relevant skills might be able to make the changes needed for 4.2
trent4
Post by trent4 »
Thank you for the info. Was really hoping it would be an easy thing to run the LSU 4.2 sensor with the onboard controller.
Myself and most others have much greater reliability with the 4.2
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
The only HW difference:
Screenshot from 2024-02-16 11-14-41.png (180.37 KiB) Viewed 991 times
SW supports both sensors on other HW.
trent4
Post by trent4 »
Thank you for the info. Unfortunately, not something I want to play with.
I think I'll just buy this: https://www.shop.rusefi.com/shop/p/dual-channel-wbo
It says that'll control a 4.2 sensor and I'll also be supporting rusEFI a little more.
In the future, I would love to see 4.2 support added to the uaEFI board, even if it costs a little more.
I'm sure most people would like the option to run either sensor as well.
