hellen121nissan in 350z nissan body but vq30det vq30 engine
Trying to use hellen121nissan in 350z body but with non-stock vq30det engine with untested trigger
- 2022-05-25_22_26_48_618rpm_0_maf_0.0.png (16.54 KiB) Viewed 11333 times
Re: hellen121nissan in 350z body but vq30det engine
Pavel says that injectors are not clicking while cranking which does not match logs. I really hope that it's a wiring problem.
is this correct firing order? really 123456?
wow it's really 123456
Overall this reminds me that we need hardware with feedback
Status update over the phone
1) with self stimulation fake trigger we have real injectors clicking (!!!)
2) with real cranking we have RPM, amazing engine sniffer, red injector LEDs on PCB are blinking and injectors are definitely not engaging. Tested by qualified real human and some LED not noid testing beeping thingy
Pavel even had direct red wire from battery to injector positive line to eliminate chance of main relay not engaging during cranking.
Overall I am convinced that it's some electrical not firmware issue, no idea what to try next
And it's a custom original harness with only one wire added for cam sensor conversion so anything could be funny.
Well at least I've made some progress on https://github.com/rusefi/rusefi/issues/4086 since it has hurt you today
https://github.com/rusefi/rusefi/commit/3cf3618eb1342669c29d338f65ca4ccef59ed233
just need a place to keep this important picture for all future usage
Re: hellen121nissan in 350z nissan body but vq30det vq30 engine
Sad, very sad spark plugs were the problem. Between new spark plugs and trigger offset 360 degrees this now runs and drives. There were no issues with fuel or injectors.
