[Solved] NB2 VVT Issue
NB2 Miata H72D. Customer reported that VVT response would drop out intermittently. It is captured in the log screenshot below. I am waiting on the tune so that i can upload the full log. Earlier in the log, VVT position seemed to be responding as it needed to. Do we have VVT target available or only duty cycle table?
Re: NB2 VVT Issue
So we have a usability issue - menu name says "target" but actual table does not specify what it is. Let's make progress here
Re: NB2 VVT Issue
At the moment rusEFI has ONLY closed-loop VVT control, it's always target never duty cycle.
At the moment I have no idea what's going on with the whole drop
Re: NB2 VVT Issue
We do not log VVT target by default
We have "debug mode" setting which gives half a dozen of VVT entry points but it has to be enabled explicitly.
See bottom of
See bottom of
Re: NB2 VVT Issue
Progress: min/max tooltips
unfinished progress: button to enable VVT PID debug mode
Re: NB2 VVT Issue
Output Max Duty Cycle?
Re: NB2 VVT Issue
I like it, done!
Re: NB2 VVT Issue
input from Tuner- "after adjusting PIDs, it seemed to resolved the issue".
I will poke the owner for updates.
Re: NB2 VVT Issue
Hello! I am the owner in question dealing with a potential vvt issue.
The vvt seems to want to work intermittently
I will include the most recent datalog hopefully showcasing the issue and the current tune the car is running
Im think that the vvt actuator may be bad as I also swapped the vvt solenoid to no effect. The car does run better with the vvt unplugged
Tune: https://rusefi.com/online/view.php?msq=700
Datalog: https://rusefi.com/online/view.php?log=394
Re: NB2 VVT Issue
Can you set debug mode to "VVT1 PID" and take another log? That will give additional information about what's going on.
Re: NB2 VVT Issue
Alright, I'll take another log with the debug mode set to that. I'll upload it once I get around to it!
Re: NB2 VVT Issue
Got the new datalog with "vvt1 pid" debug selected
The vvt would still work intermittently and would sometimes fully advance to 44-45 degrees causing the car to run terribly
Datalog:https://rusefi.com/online/view.php?log=395
Re: NB2 VVT Issue
Your hardware is fine. PID settings are pretty clearly super wrong.
Where did you get your VVT PID settings? Looking at the output duty cycle, your settings are not nearly strong enough. The controller is responding to input, but extremely slowly, so you end up with relatively random solenoid duty.
Your min/max on the VVT PID should also be further apart - try min/max of 10/70, and MUCH higher gains. Start with just some P to see what happens.
Re: NB2 VVT Issue
https://www.facebook.com/stevesremotetuning was tuning the car.mck1117 wrote: ↑Tue Nov 02, 2021 5:34 pmYour hardware is fine. PID settings are pretty clearly super wrong.
Ill give that a shot and monitor how the vvt reacts.
Re: NB2 VVT Issue
With all due respect, this means your tuner didn't actually look at VVT at all, and likely didn't actually tune your car.Nightsknight45 wrote: ↑Tue Nov 02, 2021 5:49 pmhttps://www.facebook.com/stevesremotetuning was tuning the car.
Re: NB2 VVT Issue
I was able to get the vvt to respond pretty accurately under these settings however the car has a very jerky takeoff from stops
Any input on what to change/where I should be looking to fix that? (car takes off from stops fine with vvt unplugged)
Latest Datalog: https://rusefi.com/online/view.php?log=397
Re: NB2 VVT Issue
No worries man, to be honest, you are probably right... it was sort of a waste of money for what I got.mck1117 wrote: ↑Tue Nov 02, 2021 5:53 pmWith all due respect, this means your tuner didn't actually look at VVT at all, and likely didn't actually tune your car.Nightsknight45 wrote: ↑Tue Nov 02, 2021 5:49 pmhttps://www.facebook.com/stevesremotetuning was tuning the car.
Re: NB2 VVT Issue
Awesome - this log looks MUCH better with respect to VVT control!Nightsknight45 wrote: ↑Tue Nov 02, 2021 11:10 pmI was able to get the vvt to respond pretty accurately under these settings...
it looks like your cam target table is pretty aggressive in here:Nightsknight45 wrote: ↑Tue Nov 02, 2021 11:10 pm...however the car has a very jerky takeoff from stops
The VVT target on an intake-VVT-only engine (like the NB2) is your overlap control: more cam angle = more overlap. Right now, your tune is trying to bonk in a bunch of overlap the instant you touch the accelerator, which is probably what you're feeling. Pull out that timing in the "off idle" regime, and see what happens.
Re: NB2 VVT Issue
Something like this might be worth a shot:
Re: NB2 VVT Issue
This is what i had on my old VVT car with MS.
Re: NB2 VVT Issue
Did that use TPS or MAP for the Y axis?BeerMoneyMotorsports wrote: ↑Tue Nov 02, 2021 11:28 pmThis is what i had on my old VVT car with MS.
Re: NB2 VVT Issue
rpm and load
