Hi, I've wired up temp VSS signal from the dash. I have confirmed that the dash output is 5 volts when high, and 0 volts when low, and that it switches state as the car moves. I have hooked the wire up to 1M, VSS input, I have configured tuner studio to use 1M as VSS input, but I cannot see a vehicle speed reading on the data logs. I've looked at the spaghetti diagram and I can see an input called VSS IN, connected to P33. I can see the pull up resistors R20 and R23, but if I test between these resistors (in particular R32) and P33, I read some 14K Ohms. should this be less or am I misunderstanding the design? Do I need to run a link between P33 and R32 to get VSS to work?
Thanks in advance.
Hellen64 revb 91Miata VSS
- Hellen64 Maita 91-94 revb
- hellen64na6-b.jpeg (2.54 MiB) Viewed 11792 times
- Screenshot of the spaghetti diagram
- aaabbc.jpeg (177.09 KiB) Viewed 11792 times
1991 1.6 Mazda Eunos Roadster, 5sp, Normally Aspirated
Re: Hellen64 revb 91Miata VSS
Just made an improvement in the firmware - at least we will have VSS front event counter https://github.com/rusefi/rusefi/issues/4173
But did not have a chance to test it so far
Ill update tomorrow with needed jumper for vss
Sorry for the delay. Remove r20 and jumper to p33. VSS circuit already has the pullup, so r23 can be completely bypassed.
- 020068BD-07F2-451D-911C-7F454B806C2E.jpeg (404.76 KiB) Viewed 11706 times
