[info] 2013: Frankenstein - cheaper ECU shield / official / legacy
Re: Project Frankenstein - full ECU shield
SD works, USB TTL works. Top post updated.
Time for a glass of port.
First feedback:
We need W210 and W209, the way we have W211 and W212 - that's so that we can redirect op-amp channels to digital timer inputs. todo: figure out if we can get events right on the existing pins without routing them to timer input capture pins
P401 - the three pin connector 5v 3v GND - a minor inconvenience is that a 3 position terminal is required even while we do not really have use cases for the 3v pin. reordering the pins to 3v 5v GND would make it possible to use a 2 position terminal if you do not need the 3v, but I guess it might complicate the traces.
I've verified injector driver & I've verified analog inputs - at this point I am comfortable to offer this for sale @ tindie
non-fatal issue with rev 0.1: hi-side driver: the part numbr is for SOIC package but the board has MSOP package. Part number should be TC4427AEUA
In the next revision we will probably go to a larger package
Shippedsturovo wrote:ordered
I cannot believe it. I've assembled it and it JUST WORKS!
Very nice very nice. Now I just need to convince you to break the 10cm by 10cm rule so I can put that connector all on one PCB and get rid of that spaghetti. Also it would be nice if we added an optional 2 pin jumper such that you don't have to run that red wire along the edge of the PCB. We have 5V down near the high side selection pin for the high low driver. As well I'm sure we can change the green and yellow wires into little 2 pin jumpers. At some point we should see how the injector drivers are doing thermally. It's winter now, so no problems, but on a hot summer day, with a long drive, I wonder how it would preform.
Good to see it's working cool.
Frankenstein can host a character LCD screen
Soldering chimp mode off.
#2 & #3
#2 & #3
Have you considered selling these as a "kit"?
Presumably if you order the parts in quantity it will be cheaper than everyone buying them individually. It would make it a heckuva lot easier for someone who wanted to try it too... Perhaps recommend that they buy an assortment of 0805 resistors/caps cheaply on e-bay, and you could provide the other pieces and the board for them to solder up themselves.
Just a thought!
Just a thought!
This would also be a lot of manual packaging-labeling on my side, that would be CRAZY inefficient.
Often with digikey or who ever, you can get them to do the "kitting" then you simply drop in the PCB with a package from them, and your done. However that's typically kind of expensive.
Ops, another minor issue - the diode part number is wrong, The BAR43FILM diode is a single diode with hi-side pin not connected. I believe the correct diode is BAR43ASFILM.
The good news is that the incorrect diode does offer protection above 5V, which is what most people need and want. The bad news is that the desired diode which provides some below 0V protection is made from un-obtainium. A different diode will need to be selected to get both the over voltage and under voltage protection.
BOM updated - new part # is 497-2516-1-ND
Q: what are these red, yellow and green jumper wires? do I need them?
A: red jumper wire is +5 going to 'VP' pin which is shared by all hi-side drivers. By running a +5 red wire you make these channels output 5 volts. I believe you can also run it to +12 if you need to, and you can ground it and convert these drivers into low-side.
Yellow is primary trigger channel and green is secondary trigger channel, these are here to let you choose between using the VR chip or op-amps for your input. If you have the VR cheap, use it. If you are too cheap and you know that op-amp would work for you, use the op-amp channels 11 and 12.
First of all, congratulation that the kick starter is funded. I bought the Frankenstein PCB through it. Just started trying to order parts from Digikey.
There is a few parts that are back ordered but this part TC4427AVOA-ND (1.5A dual driver) seems to have a high minimum order (>600) to even put in an order.
A quick search shows that Mouser is the same deal. Any replacement for that for small quantity order?
True, I have never seen this part available for small orders @ Digikey. I did have better success with it on Mouser, looks like you can order it now but it's backordered so there would be a wait. Another option would be trying to go with TC4426 - that's an inverting version of the same chip, we have support for inverted mode in the software so as long as you do not forget to apply the inversion while configuring that should work.20div0 wrote:There is a few parts that are back ordered but this part TC4427AVOA-ND (1.5A dual driver) seems to have a high minimum order (>600) to even put in an order. A quick search shows that Mouser is the same deal.
Another components which you have to source separately is the micro-sd card - somewhere here there is a link to the eBay. The BOM is know to be good enough, it is maybe lacking with the connectors but that's because everyone would have his own preference for the connectors - or total lack of them (soldering wires right to Frankenstein)
Thank you a lot for supporting the KS!
So, a little more research... the closest part to it is the TC4427AEOA-ND which has a lower temperature range on the high side (85C vs 125C). Is 85 C good enough? Can I put a heat sink on it? The inverted version also has minimum order of 600 in digikey.
I guess we do not have much choice but to go with +85. Looks like the ones I have are the same temp rating.
Until someone tries that in Arizona in summer we simply do not know. Also depends on actual ignition module current, which might be lower than 1.5A
The lower temperature rating should be fine within some specific parameters. The internal resistance of this chip will generate a certain number of watts per P=(I^2)R. Then the data sheet's specified thermal resistance will tell you the amount of current that can be passed via this chip before the chip hits that max temperature spec. If we believe the datasheet thermal resistance, the 125C chip was limited to .125A. The lower temperature chip would have a lower max current limit. However if you add a heat sink, you can decrease the thermal resistance by an unknown amount, which then increases the current you can pass before you hit the temperature limits of the chip. Do you plan for more than .125 amps of drive? If so what do you plan for a max ambient temperature?
I tried to document the general environment design parameters here http://rusefi.com/wiki/index.php?title=Manual:Hardware#General_suggested_environment where I put the design max ambient at 50C. So I originally planned for a 75C, and this lower temperature chip would drop that to 35C, so I would expect you will either need a heat sink, or you'll need to draw significantly less than .125A.
Do you have a general system schematic you can share? If we review it we might be able to better help guide your choices in components. If you need some kind of external component, might as well get it all in one order if possible. I suspect you are using the hi/lo for ignition. If so, you are probably drawing less than .125A any how so you are probably just fine with the lower temperature spec and no heat sink. But I would need to know more before I can really predict if that will be OK or not.
I don't have any design yet. I wanted to support the project on kick starter and just getting started. I want to order the STM32F DISCOVERY board to play with, so might as well order all the parts. I will probably order the lower temp part for now since they are just a few bucks. Thanks.
Sounds good. There isn't any real issue with the lower temp part, you might want to get a small heat sink if you can, such that when and if you use it, you have the option of pushing more current through it. Let me know if you have any questions. I'll see what I can do. Just FYI, I work the 40 and have many typically life constraints. So I might take a day or two to reply, and I might need an occasional bump if it gets lost in the weeds.
Thanks a lot. I probably won't be controlling injectors for a while. My plan is to first read the RPM and control the solenoids in my SR20VE and also try to read the AC pressure sensor and turn the compressor off when it's too high. I will probably start a new thread when I get to it so I don't pollute this thread two much.
Just lerking here and am curious if you think this will affect me KB? Summer can easy hit 44C and then put that ecu in the car and skies the limit eh. Cheers M8.....kb1gtt wrote:So I originally planned for a 75C, and this lower temperature chip would drop that to 35C, so I would expect you will either need a heat sink, or you'll need to draw significantly less than .125A.
Jay
Nothing is ever broken, it's just a mater of patience, resources and persistence to fix it!!! Oh yeah and knowing when it's worth it or not!!!
At an ambient of 44C and high RPM, this would be in the realm of unknown. I believe you will be ok but you are getting close to the edge of my design specs so I'm not quite sure. I would suggest aiming for significant heat sinkingand try to place in a cool area with air flow. I have noticed it's common for OEMs to put the ECU heatsink in the intake air filter. I'm not a fan but though I would mention as it was not something I would have though about before seeing it. If worst comes to worst we can add a fan to the heat sink.
I was planing that to preempt and add reliability in Australian conditions these things will probably be needed anyway...kb1gtt wrote:At an ambient of 44C and high RPM, this would be in the realm of unknown. If worst comes to worst we can add a fan to the heat sink.
I posted the design specs here http://rusefi.com/wiki/index.php?title=Manual:Hardware#General_suggested_environment My goal is for 50C ambient, so you should be good, but at 44C, you are getting closer to my design goals and we know if my predictions are correct tor not right now. Perhaps it's worth while to check the other goals and see if anything else jumps out at you. Frankenso has several temperature sensors, which plan to use for verification of the ECU's thermal design, and long term safeties.
Hello All,
I just finished reading through this thread and all I can say is Holy Smokes!!
I really loved seeing this project develope and move along. I was wondering how this would work for a V8 engine. I'm assuming the engine it was tested on was a V6.
And are there any final cost projections. I intend to do the DIY thing with this project. And was trying to get a ball park estimate on cost.
I'll be following this clostly..
Congrats on the progress!
