A breakout board for Chrysler NGC connector.
https://svn.code.sf.net/p/rusefi/code/trunk/hardware/NGC_38_connector/
Case: https://www.tinkercad.com/things/dwXC24Jn2AG-single-ngc-38-box-v03
Order from Oshpark
[info] NGC 38 pin connector
Re: NGC 38 pin connector
the board is too tall this makes the shell for it HUGE https://tinkercad.com/things/fKZ8OSqr5zQ-38-draft-3
I guess we do not really need two holes for each wire, one would be enough. If we center the board and shrink it by 6mm on each side things should get smaller.
- 38pin_case[1].jpg (819.88 KiB) Viewed 3501 times
