[rusEfi] Mitsubishi 4G63 and 4G92 (#6)
- Tambralinga
- donator
Re: Mitsubishi 4G63 and 4G92 (#6)
You can assign fan to any pin of Frankenso or Frankenstein, you can customize this via TS.Tambralinga wrote:What pin use for fan on Board Frankenso ?
No. I do not understand you hereTambralinga wrote:Firmware have time out 1 minute?
- Tambralinga
- donator
Ok, Problems with my cable.russian wrote:You can assign fan to any pin of Frankenso or Frankenstein, you can customize this via TS.Tambralinga wrote:What pin use for fan on Board Frankenso ?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
- Tambralinga
- donator
WowTambralinga wrote:
I was suspecting something was going on
cool! two usb ports, embedded bluetooth! a set of microswitches, integrated power supply! what else?! sexy! what connecters are you using?
very nice very nice. Keep up the good work.
Also beware the DB connectors. Those were not designed for 1A of current flow, and is a common reason for problems on other system designs. I would suggest a better connector, or at least using the gold plated contacts for those connectors.
- Tambralinga
- donator
puff wrote:cool! two usb ports, embedded bluetooth! a set of microswitches, integrated power supply! what else?! sexy! what connecters are you using?
DB9 : That for External LCD Display... any status.
DB27 : For external exhaust sensors.
;-x
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
- Tambralinga
- donator
Thanks for your concern.kb1gtt wrote:very nice very nice. Keep up the good work.
According to connector, I have nothing the right connector. Waiting for a new one should be strong connectors.
I have one question about Knock sensors.
I don't know in "Frankenso" can use or not. Because I have no experience in the Knock.
If you have any concern, please let me know.
Thanks.
Mr.X
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
- Tambralinga
- donator
Frankenso single board.Tambralinga wrote:
my frankenso
;-x
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
The firmware for this is not ready yet, but it's pretty high on the priority list.Tambralinga wrote:I have one question about Knock sensors.
This is pretty cool! Does it work? Did you run an engine with it?Tambralinga wrote:Frankenso single board.
http://rusefi.com/wiki/index.php?title=Manual:Flexible_LogicTambralinga wrote:I want to open solenoid at 5000-5500 RPM output signal GND to solenoid.
- Tambralinga
- donator
russian wrote:http://rusefi.com/wiki/index.php?title=Manual:Flexible_LogicTambralinga wrote:I want to open solenoid at 5000-5500 RPM output signal GND to solenoid.
Ok,Tomorrow I will test.
set_fsio 1 5500
set_fsio_pin 1 pd11
Use this command to open solenoid @ RPM 5500 or not
You have command for change fuel table 24x16 or 32x16 ?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
5500 what? this is not how this works - you need to specify that you are comparing 5500 and rpmTambralinga wrote:set_fsio 1 5500
so, more like
set_fsio 1 "rpm 5500 >"
To get larger fuel maps you would need to re-compile the source code & adjust rusefi.ini
- Tambralinga
- donator
set_fsio_pin 1 PE2
It does not work.
I want example for shift light open rpm 7000.
set_fsio_pin 1 PE2
It does not work.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
Please update to latest version #5717
I have hard-coded something into your config, so you would need to reset configuration
set_engine_type 16
The hard-coded stuff is:
fsioinfo should show the state of. At low RPM, it shows
set_engine_type 16
setFsio(engineConfiguration, 0, GPIOD_11, "rpm 5500 >");
At high RPM, it shows2014-12-07 10_35: EngineState: FSIO #1 [rpm 5500 >] at PD11@0Hz = 0.00000
2014-12-07 10_35: EngineState: user-defined #1 value=0.00000
2014-12-07 10_36: EngineState: FSIO #1 [rpm 5500 >] at PD11@0Hz = 1.00000
2014-12-07 10_36: EngineState: user-defined #1 value=1.00000
- Tambralinga
- donator
new firmware set_engine_type 16 problems connecting to TS.
Connect no more than 1 minute disconnected.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
- Tambralinga
- donator
I want to change in the Y Axis maximum cranking coolang temp to more than 500.
I can not change my eclip have an error, you can change it.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
but why? 500 is already unrealistic.Tambralinga wrote:I want to change in the Y Axis maximum cranking coolang temp to more than 500.
Not sure which field exactly you are referring to, can you please share a screenshot?
- Tambralinga
- donator
donecrankingFuelCoef = array, F32, 9504, [8], "%", 100, 0, 0.0, 700.0, 2; size 32
- Tambralinga
- donator
- Tambralinga
- donator
firmware new version 26-01-58 have error led red show.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
Anything on the LCD screen?Tambralinga wrote:firmware new version 26-01-58 have error led red show.
I think I have fixed it, please try latest firmware.
- Tambralinga
- donator
my lcd damage Today I will test the new firmware .russian wrote:Anything on the LCD screen?Tambralinga wrote:firmware new version 26-01-58 have error led red show.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
- Tambralinga
- donator
not work for last firmwarerussian wrote:I think I have fixed it, please try latest firmware.
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
Can you reproduce this issue right from full chip erase & create a ticket?
https://sourceforge.net/p/rusefi/tickets/132/ is an example of a ticket with FULL & EXACT steps to reproduce. It also contains the exact version of the binaries where the problem is reproduceable.
- Tambralinga
- donator
You have a command for a matching offset or silk create file ini ?
Skype : shiva-p
+66 8 5357 5159
+66 8 5357 5159
Not sure what you mean here do not understand what is this question about
get_int command? set_int command?
