This really sucks! The software was actually quite good. Although I don't rely on it 100%, the software allows me to get better visuals on routing and shows me new paths that I may not have seen. It has definitely save me times. It is a sad day now that it is gone.
Anyone know a alternative?
Freerouting.net is dead
Re: Freerouting.net is dead
Wow, that's a blow I hope the community is large enough for someone to figure it out.
I know @ have used TopoR with KiCad, it's commercial software but I believe the free version would work for us.
http://eda.eremex.com/
http://eda.eremex.com/cms/f/453954/TopoR%206.0eng.pdf
Although he states there that it won't run with the latest java runtime, I believe there is some sense in writing to him, asking him to provide you with sources, so that you could run it locally?
btw wtf is Zuken?
btw wtf is Zuken?
The source codes are available at least at https://github.com/nikropht/FreeRouting
See also http://www.freerouting.net/fen/viewtopic.php?f=4&t=255
freeroute web version
I'm use TopoRrussian wrote:Wow, that's a blow I hope the community is large enough for someone to figure it out.
& OFFLINE version freeroute on Linux (no need internet connection)
@ has emailed me an offline version of FreeRouting - here it is
There is also http://thepiratebay.se/torrent/10374368/Freerouting.net_Freerouter_%28Ubundu___Debian_Linux%29 but looks like there are no seeders online.
Also http://thepiratebay.se/torrent/10416273 for the jnlp (java web start) local version - this one would work on Windows
As people study the autorouter, perhaps they could figure a way to get it to place vias in a zone area. Basically, when you are trying to remove the FR4 glass and replace with more thermally conductive materials like copper and TIN plating, it would be handy to have something attempt to place a via and if it clears leave it, if it does not have the proper setbacks / clearances, then try again like .010 inch to the side.
A brief update: now we have https://freerouting.org/ probably owned by https://layouteditor.org/info/impressum
And there is maybe/probably an unrelated https://github.com/miho/freerouting which seems to be the most active fork of https://github.com/freerouting/freerouting
I've just restored access to https://github.com/freerouting/freerouting and merged https://github.com/miho/freerouting into https://github.com/freerouting/freerouting
