[rusEfi] 1993 Mazda Protege (#3)
Mazda 323 Sixth generation (BG; 1989–1994), also related to Ford Escort GT (North America) Mazda BP is a popular engine swap for Ford Festiva (Mazda 121), same engine is also used in Mazda Miata/MX-5
Trigger shape:
http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Protege_1993
Full(?) ECU pinout:
https://docs.google.com/spreadsheet/ccc?key=0Arl1FeMZcfisdElBTkFFWXFyR3NReENNSU51OXVxa0E
Trigger shape:
Full(?) ECU pinout:
Re: 1993 Mazda Protege
Minimalistic wiring:
4/1G Igniter
12/1B +12 in start and run
1/2A Ground Injector
3/2E secondary trigger input
4/2G primary trigger input
6/2K +5v air meter power supply
8/2O air flow meter
11/2U Injector (1&3)
15/2D Ground - sensor return
24/2Y injector (2&4)
4/1G Igniter
8/2O air flow meter
So that's less than 48 hours since I've decided to start engine #3 for a demo at a Lemons race next weekend:
Nice, nice. Also cool that I didn't have to offer much help. Your getting better with the electrical stuff. So, how long until the mini is going?
So as a re-cap of the time line, this would be the major steps start to finish.
1. Cam and crank were sniffed on April 10th, with a low cost logic analyzer.
2. Firmware was written to decode the crank / cam signal(s).
3. Injectors and ignition were connected to Frankenstein via OEM like harness adapter.
4. Fuel injectors, spark control, and such were tuned.
5. Engine was cranked and started on the April 12th. Which left you with Sunday to rest or fine tune it even more.
Not a bad time line, basically it's start to finish in 48 hours or less. Is that correct? I think total material cost was also less then $200 is that correct?
Oh, also I think you were working on Friday, so not all those hours count, also I know I bugged you from time to time about various other items. So again other distractions that took some time away from doing this engine 100% of the time. So well under 48 hours if I understand it correctly.
Cam signals (these are both cam signals - two sensors inside the distributor) were sniffed and recorded a year or two ago, but apparently nothing has changed since.
In this uber-minimalistic version the ECU board + brain board are really pushing the $100 threshold.
is it the third one running rusefi?!
Hi, nice work you have done
Are you thinking in make some thing to Z5 engine?
Keep the good work.
Keep the good work.
Thank you for the warm words. I do not have a Z5 engine to play with, but since rusEfi is universal you should be able to make yourself one, too. In case something you be missing I will implement whatever is missingpauloasbrito wrote:Are you thinking in make some thing to Z5 engine?
Keep the good work.
Re: 1993 Mazda Protege (#3)
New board for the Festiva under new management
I have a few of those decals for you...and can make other sizes if you need them
Ford Festiva with Mazda Protege Block, Mazda Miata BP4W head and Protege intake w/mods, Ford Escort GT transmission ----- yup, it is a lemon!!! --- fun site https://mixdrinkenjoy.com
I need a couple to put on my trucktigeryan wrote:I have a few of those decals for you...
How big do you want them? I can go up to 11" tall, unlimited long
