rusefi.com The most advanced open source ECU 2023-12-06T06:39:51 https://rusefi.com/forum/app.php/feed/topic/1077 2023-12-06T06:39:51 2023-12-06T06:39:51 https://rusefi.com/forum/viewtopic.php?t=1077&p=48749#p48749 <![CDATA[Re: hello all - Mitsubishi #31]]>
I been silent nearly 1 year. :D
My next plan is change bottom block with 4g63, wild cam (294/294) booated with td05 Mitsubishi turbo.
Trigger will be Yoshifab 24/1 to get more resolution.
One question:
Do Rusefi support this trigger?
Hi Matt, I'm from Malaysia too. is there anyway I could get in touch with you. If possible, drop me a text 0127090659, would love to pick your thoughts on RUSefi
Statistics: Posted by nishirams — Wed Dec 06, 2023 6:39 am
2018-09-23T13:24:45 2018-09-23T13:24:45 https://rusefi.com/forum/viewtopic.php?t=1077&p=30163#p30163 <![CDATA[Re: hello all - Mitsubishi #31]]> Statistics: Posted by AndreyB — Sun Sep 23, 2018 1:24 pm
2018-09-21T17:40:27 2018-09-21T17:40:27 https://rusefi.com/forum/viewtopic.php?t=1077&p=30140#p30140 <![CDATA[Re: hello all - Mitsubishi #31]]>
One question:
Statistics: Posted by matt — Fri Sep 21, 2018 5:40 pm
2017-03-13T14:15:24 2017-03-13T14:15:24 https://rusefi.com/forum/viewtopic.php?t=1077&p=24310#p24310 <![CDATA[Re: hello all - Mitsubishi #31]]>
not much launch control logic in rusEfi at the moment
Statistics: Posted by AndreyB — Mon Mar 13, 2017 2:15 pm
2017-03-13T08:22:48 2017-03-13T08:22:48 https://rusefi.com/forum/viewtopic.php?t=1077&p=24308#p24308 <![CDATA[Re: hello all - Mitsubishi #31]]> what is setting at tunerstudio should be?
Statistics: Posted by matt — Mon Mar 13, 2017 8:22 am
2017-03-09T20:38:58 2017-03-09T20:38:58 https://rusefi.com/forum/viewtopic.php?t=1077&p=24262#p24262 <![CDATA[Re: hello all - Mitsubishi #31]]> Statistics: Posted by stefanst — Thu Mar 09, 2017 8:38 pm
2017-03-09T13:13:02 2017-03-09T13:13:02 https://rusefi.com/forum/viewtopic.php?t=1077&p=24261#p24261 <![CDATA[Re: hello all - Mitsubishi #31]]>
Was your alternator ECU controlled or is that controlled internal by the alternator?
i believe it controlled internal.
Statistics: Posted by matt — Thu Mar 09, 2017 1:13 pm
2017-03-09T13:02:50 2017-03-09T13:02:50 https://rusefi.com/forum/viewtopic.php?t=1077&p=24260#p24260 <![CDATA[Re: hello all - Mitsubishi #31]]>
Statistics: Posted by kb1gtt — Thu Mar 09, 2017 1:02 pm
2017-03-09T12:55:33 2017-03-09T12:55:33 https://rusefi.com/forum/viewtopic.php?t=1077&p=24259#p24259 <![CDATA[Re: hello all - Mitsubishi #31]]> can i use multi meter to measure current.
Statistics: Posted by matt — Thu Mar 09, 2017 12:55 pm
2017-03-09T12:23:46 2017-03-09T12:23:46 https://rusefi.com/forum/viewtopic.php?t=1077&p=24258#p24258 <![CDATA[Re: hello all - Mitsubishi #31]]> Statistics: Posted by kb1gtt — Thu Mar 09, 2017 12:23 pm
2017-03-09T11:59:02 2017-03-09T11:59:02 https://rusefi.com/forum/viewtopic.php?t=1077&p=24257#p24257 <![CDATA[Re: hello all - Mitsubishi #31]]> really need bigger injector.
it is normal voltage drop to 12v at high rpm?
Statistics: Posted by matt — Thu Mar 09, 2017 11:59 am
2017-03-09T06:28:08 2017-03-09T06:28:08 https://rusefi.com/forum/viewtopic.php?t=1077&p=24255#p24255 <![CDATA[Re: hello all - Mitsubishi #31]]>
Just fixed #370 so the error code would disappear.
Why these two green spikes? Lean/rich/lean around where you let off throttle pedal?
no idea. wideband sensor is mount at back of exhaust pipe. so maybe outside O2 came in or maybe my bad grounding cause this.
Statistics: Posted by matt — Thu Mar 09, 2017 6:28 am
2017-03-09T06:24:15 2017-03-09T06:24:15 https://rusefi.com/forum/viewtopic.php?t=1077&p=24254#p24254 <![CDATA[Re: hello all - Mitsubishi #31]]>
Do you have some after-market forced induction? Wonder why are OEM injectors not enough.
none. my engine is mitsubishi 4g61 n/a, engine block rebore to 86mm to fit with toyota caldina high comp piston.
got fix something yesterday. i add more grounding cable and my ligh seems brighter then before.
and also got fix my 12v input. i will test it this evening and post a log.
Statistics: Posted by matt — Thu Mar 09, 2017 6:24 am
2017-03-09T06:16:46 2017-03-09T06:16:46 https://rusefi.com/forum/viewtopic.php?t=1077&p=24253#p24253 <![CDATA[Re: hello all - Mitsubishi #31]]>
Statistics: Posted by AndreyB — Thu Mar 09, 2017 6:16 am
2017-03-09T05:46:17 2017-03-09T05:46:17 https://rusefi.com/forum/viewtopic.php?t=1077&p=24252#p24252 <![CDATA[Re: hello all - Mitsubishi #31]]> https://github.com/rusefi/rusefi/issues/370
Looks like error code 6050 is thrown by mistake here
Statistics: Posted by AndreyB — Thu Mar 09, 2017 5:46 am
