The 466 is more obvious how it works, but also doesn't have the automagic measurement stuff. Simpler is handy because when a switch goes bad, it's easier to figure out that it's the switch. The 2246 has a bunch of "digital" brains which can go bad, then you have to diagnose if the switch is bad, or if the digital circuit has gone bad. I would suggest the 466 as it's simpler, but the measurements of the 2246 are handy. However the complexity of the 2246 is also going to make it fail more. Both are better than nothing, and it's not a huge difference between them in terms of ability to better measure noise. I would say get which ever one has better probes. Probes are a large part of getting a good noise free signal.Statistics: Posted by kb1gtt — Fri Oct 28, 2016 11:26 pm
