rusefi.com The most advanced open source ECU 2024-12-11T23:19:48 https://rusefi.com/forum/app.php/feed/topic/1115 2024-12-11T23:19:48 2024-12-11T23:19:48 https://rusefi.com/forum/viewtopic.php?t=1115&p=50255#p50255 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #26]]>
Did you get this VR working correctly?
topic is 8 years old
uaEFI VR decoder handles Honda
Statistics: Posted by AndreyB — Wed Dec 11, 2024 11:19 pm
2024-12-11T23:05:57 2024-12-11T23:05:57 https://rusefi.com/forum/viewtopic.php?t=1115&p=50254#p50254 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #26]]> Statistics: Posted by lysdex — Wed Dec 11, 2024 11:05 pm
2016-11-04T10:53:36 2016-11-04T10:53:36 https://rusefi.com/forum/viewtopic.php?t=1115&p=20980#p20980 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #26]]> Statistics: Posted by AndreyB — Fri Nov 04, 2016 10:53 am
2016-11-04T08:56:25 2016-11-04T08:56:25 https://rusefi.com/forum/viewtopic.php?t=1115&p=20978#p20978 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #25]]> Statistics: Posted by kb1gtt — Fri Nov 04, 2016 8:56 am
2016-11-04T04:08:03 2016-11-04T04:08:03 https://rusefi.com/forum/viewtopic.php?t=1115&p=20974#p20974 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #25]]>
Oh and I also notice that the tunerstudio timing gauge also jump around a bit when applying some throttle 14, 12.7, 12, ...
Statistics: Posted by maximus64 — Fri Nov 04, 2016 4:08 am
2016-11-01T05:26:40 2016-11-01T05:26:40 https://rusefi.com/forum/viewtopic.php?t=1115&p=20914#p20914 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #25]]> I also ordered an SLC-FREE WideBand controller (http://www.14point7.com/products/slc-free) and I'm also in the process of building an engine simulator heh
Statistics: Posted by maximus64 — Tue Nov 01, 2016 5:26 am
2016-10-31T01:15:35 2016-10-31T01:15:35 https://rusefi.com/forum/viewtopic.php?t=1115&p=20890#p20890 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]>
OK, so QUCS R0.19-snapshot has a bug when trying to use SPICE imported devices. I got this QUCS model to work by first un-installing QUCS and installing it into "C:\Qucs" note this has no spaces, and the default includes "program files" which has a space. Once QUCS is installed with no spaces, then you need tinyperl and you'll need to specify that it's installed in "C:\Qucs\bin" Notice the default will try to install into a folder which won't work. It needs to be in the root bin folder.
Then I added a ".END" after the ".ENDS" in the PSpice file, and QUCS stopped complaining about things. Here's the files which attempt to use the PSpice model. I suspect that the linux versions would do this just fine. I think the issues I'm having are windows related. I've only found people complaining about it who were also windows people.
https://cp.sync.com/dl/4a63cdb70#rtbmyrt9-dnxg94q6-xnazzdxt-bx8y8t7a
Statistics: Posted by kb1gtt — Mon Oct 31, 2016 1:15 am
2016-10-30T04:38:41 2016-10-30T04:38:41 https://rusefi.com/forum/viewtopic.php?t=1115&p=20880#p20880 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]>
Here's the list from QUCS. Do any of these look to have the open collector you noted? They didn't seem to work the way I was hoping or expecting, so I doubt it and it's a small list.
I check each of them and most are just general purpose op-amp, but you could convert the output signal to open collector and play with it.
So far the VR board seem to work nicely. I haven't tried above 4000 RPM yet due to no tune.
Statistics: Posted by maximus64 — Sun Oct 30, 2016 4:38 am
2016-10-30T04:05:01 2016-10-30T04:05:01 https://rusefi.com/forum/viewtopic.php?t=1115&p=20878#p20878 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]> Statistics: Posted by kb1gtt — Sun Oct 30, 2016 4:05 am
2016-10-30T02:52:54 2016-10-30T02:52:54 https://rusefi.com/forum/viewtopic.php?t=1115&p=20874#p20874 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]>
I still haven't able to get rid of the stuttering yet.
Statistics: Posted by maximus64 — Sun Oct 30, 2016 2:52 am
2016-10-30T01:35:15 2016-10-30T01:35:15 https://rusefi.com/forum/viewtopic.php?t=1115&p=20872#p20872 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]>
LTSPICE doesn't have open collector comparator so I just rig up some transistors
Statistics: Posted by maximus64 — Sun Oct 30, 2016 1:35 am
2016-10-30T00:35:27 2016-10-30T00:35:27 https://rusefi.com/forum/viewtopic.php?t=1115&p=20870#p20870 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]> VR_circuit.pnghttps://cp.sync.com/dl/51f06f7d0#sja4r376-mtmdvjsa-nmdvm53c-u6ianr82
Statistics: Posted by kb1gtt — Sun Oct 30, 2016 12:35 am
2016-10-29T20:32:22 2016-10-29T20:32:22 https://rusefi.com/forum/viewtopic.php?t=1115&p=20867#p20867 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]>
Schematic:
https://www.dropbox.com/s/t23hil8vccm56mi/vr_circuit.pdf?dl=0
Kicad Project:
https://www.dropbox.com/sh/klta9apg37xmeyy/AADsa9HaYyMjfQZlnalKJxIya?dl=0
copy-paste of these files just to save them here
Statistics: Posted by AndreyB — Sat Oct 29, 2016 8:32 pm
2016-10-29T20:28:33 2016-10-29T20:28:33 https://rusefi.com/forum/viewtopic.php?t=1115&p=20865#p20865 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]> http://rusefi.com/wiki/index.php?title=Manual:Hardware_Trigger#VR_lower_level_details.2C_formulas.2C_app_notes.2C_etc
Awesome post about the VR. I created a quick QUCS such that those of us who do not have the circuit can see what it does.
QUCS schematic file found here.
https://cp.sync.com/dl/6a5ff5be0#u7d2xz84-nghw2b44-q233hu3z-ynmah2hc
Statistics: Posted by kb1gtt — Sat Oct 29, 2016 8:28 pm
2016-10-29T19:07:51 2016-10-29T19:07:51 https://rusefi.com/forum/viewtopic.php?t=1115&p=20862#p20862 <![CDATA[Re: 1999 Honda Civic stock D16Y8 #24]]> Image
Schematic:
Kicad Project:
Statistics: Posted by maximus64 — Sat Oct 29, 2016 7:07 pm
