rusefi.com The most advanced open source ECU 2017-07-18T21:06:07 https://rusefi.com/forum/app.php/feed/topic/1127 2017-07-18T21:06:07 2017-07-18T21:06:07 https://rusefi.com/forum/viewtopic.php?t=1127&p=26736#p26736 <![CDATA[Re: Engine control Logic - enginelab example]]>
Big day!
The excitement was short lived though once I calmed down and had a look at the logs.....lots of stuff need attention everywhere ...including the lying O2 sensors.
Tonight it was a little Smokey but it's finally starting to sound right
[video]https://youtu.be/2cOeKkw_0JI[/video]
Statistics: Posted by mk e — Tue Jul 18, 2017 9:06 pm
2017-06-23T06:29:27 2017-06-23T06:29:27 https://rusefi.com/forum/viewtopic.php?t=1127&p=26518#p26518 <![CDATA[Re: Engine control Logic - enginelab example]]> Statistics: Posted by AndreyB — Fri Jun 23, 2017 6:29 am
2017-06-23T01:41:31 2017-06-23T01:41:31 https://rusefi.com/forum/viewtopic.php?t=1127&p=26517#p26517 <![CDATA[Re: Engine control Logic - enginelab example]]>
https://youtu.be/Pz-Oj4xJi2w
Tonight or was running without any backfiring or any other drama with 1.0ish lambda on both banks idle redline. Time to drink.
Statistics: Posted by mk e — Fri Jun 23, 2017 1:41 am
2017-04-12T05:36:04 2017-04-12T05:36:04 https://rusefi.com/forum/viewtopic.php?t=1127&p=24938#p24938 <![CDATA[Re: Engine control Logic - enginelab example]]>
That would allow us to estimate effects of jitter to afr, ect and cylinder pressure?
Statistics: Posted by jalava — Wed Apr 12, 2017 5:36 am
2017-04-12T00:18:01 2017-04-12T00:18:01 https://rusefi.com/forum/viewtopic.php?t=1127&p=24933#p24933 <![CDATA[Re: Engine control Logic - enginelab example]]>
So.. we could connect brain board to this using the usb drivers provided if we can emulate the AEM/EL protocol and then develop the ECU without having it bolted on engine all the time you want to test stuff?
You don't need to connect anything, this runs on a Windows pc. You can only run EL models but you can still test any control logic you're interested in. I could probably make the engine simulation better and more complete but it's pretty good I think.
Statistics: Posted by mk e — Wed Apr 12, 2017 12:18 am
2017-04-11T23:36:24 2017-04-11T23:36:24 https://rusefi.com/forum/viewtopic.php?t=1127&p=24931#p24931 <![CDATA[Re: Engine control Logic - enginelab example]]>
Of course that would be as good as the engine simulation but would allow testing quite a lot of stuff out.
Statistics: Posted by jalava — Tue Apr 11, 2017 11:36 pm
2017-03-23T18:07:58 2017-03-23T18:07:58 https://rusefi.com/forum/viewtopic.php?t=1127&p=24527#p24527 <![CDATA[Re: Engine control Logic - enginelab example]]>
First of all - I'm sorry for the incident. On the other hand, let's look at it this way - you cannot make important stuff without making important mistakes from time to time.
Now, thanks a lot for this thread! I am a computer engineer currently interested in car mechanics and car tuning, and this engine simulation environment has made my day. I will keep tinkering with it for a while.
The mess is pretty much all cleaned up at this point....and finalizing the plans for a detached garage/shop.
Glad its useful.
I made a few little changes to the engine control code, the attached version seems to run the engine correctly. I'm still working on a lot of other things so I can't say everything works the way I planned yet but it seems to be pretty close.
If you figure out how to make the simulator better please share :)
Statistics: Posted by mk e — Thu Mar 23, 2017 6:07 pm
2017-03-23T16:38:42 2017-03-23T16:38:42 https://rusefi.com/forum/viewtopic.php?t=1127&p=24516#p24516 <![CDATA[Re: Engine control Logic - enginelab example]]>
Yes......I had a pinched injector wire that i found and fixed, but the injectors are 1000cc/min and one was spraying fuel any time the key was on. Best i can tell it filled the muffler and when the engine started it spray about 1/2 - 1gallon of gas out in a 4x15 foot flaming mess. No injuries but the shop is in the basement of our house....28k in cleanup costs before repairs and ruined stuff is replaced which probably another 10k. The estmate for the car is 6k. The engine itself was not hurt.....thank goodness for insurance.
Statistics: Posted by megatroneye — Thu Mar 23, 2017 4:38 pm
2017-01-17T03:19:31 2017-01-17T03:19:31 https://rusefi.com/forum/viewtopic.php?t=1127&p=22607#p22607 <![CDATA[Re: Engine control Logic - enginelab example]]>
The car got banished to the garage today....and got it's first bath in 10 years on the way. then I'm losing most of the basement and the shop will need to be walled off with double drywall and it's own hvac. Lots to do
Statistics: Posted by mk e — Tue Jan 17, 2017 3:19 am
2017-01-17T02:17:55 2017-01-17T02:17:55 https://rusefi.com/forum/viewtopic.php?t=1127&p=22605#p22605 <![CDATA[Re: Engine control Logic - enginelab example]]> Statistics: Posted by AndreyB — Tue Jan 17, 2017 2:17 am
2017-01-17T02:11:05 2017-01-17T02:11:05 https://rusefi.com/forum/viewtopic.php?t=1127&p=22604#p22604 <![CDATA[Re: Engine control Logic - enginelab example]]> Statistics: Posted by mk e — Tue Jan 17, 2017 2:11 am
2017-01-17T01:09:29 2017-01-17T01:09:29 https://rusefi.com/forum/viewtopic.php?t=1127&p=22601#p22601 <![CDATA[Re: Engine control Logic - enginelab example]]>
before i set the shop on fire
hold on, you serious? are you fine? is your garage fine? is the engine fine?
PS: is this picture upside down?
Statistics: Posted by AndreyB — Tue Jan 17, 2017 1:09 am
2017-01-17T00:52:34 2017-01-17T00:52:34 https://rusefi.com/forum/viewtopic.php?t=1127&p=22597#p22597 <![CDATA[Re: Engine control Logic - enginelab example]]>
Note to self....don't start cars for the first time inside.........
Statistics: Posted by mk e — Tue Jan 17, 2017 12:52 am
2016-12-11T13:38:26 2016-12-11T13:38:26 https://rusefi.com/forum/viewtopic.php?t=1127&p=21397#p21397 <![CDATA[Re: Engine control Logic - enginelab example]]>
dear god, can't imagine the complexities associated with that.
Not like designing an adapter plate or something, has to work on a human.
unless you meant medical devices as in "marital aids". then that is another story. :lol:
It's a lot of statistics or at least it was when I was doing stuff for fixing hearts, I moved to dental a few months ago which for the most part isn't going to kill anyone and in most about aesthetic and price.
Back on topic, the layout is fast. Literally right-click>select what you want to add (gauge, slider, etc.), select the channel it should be reading/writing, the drag it into place. You could build that whole layout from scratch in under an hour.
For me, (not being a programmer and prone to many, many typos) its really nice to be able to get the ECU to do what I want and try it on the PC not an engine. Testing on a PC also means I can "work on the car" at lunch time so its not so hard to find quite time away from the kids to do it.
Statistics: Posted by mk e — Sun Dec 11, 2016 1:38 pm
2016-12-10T23:25:34 2016-12-10T23:25:34 https://rusefi.com/forum/viewtopic.php?t=1127&p=21387#p21387 <![CDATA[Re: Engine control Logic - enginelab example]]>
LOL.....I design medical devices in my day job so you're good :)
That sounds pretty serious. So your an EE?
ME
Statistics: Posted by RustyGargoyle — Sat Dec 10, 2016 11:25 pm
