rusefi.com The most advanced open source ECU 2021-10-29T01:25:33 https://rusefi.com/forum/app.php/feed/topic/1150 2021-10-29T01:25:33 2021-10-29T01:25:33 https://rusefi.com/forum/viewtopic.php?t=1150&p=42890#p42890 <![CDATA[Re: Hello from central NJ]]>
now I'm fitting a K24 engine from a TSX
https://rusefi.com/forum/viewtopic.php?p=42855#p42855
Statistics: Posted by AndreyB — Fri Oct 29, 2021 1:25 am
2021-10-29T00:39:38 2021-10-29T00:39:38 https://rusefi.com/forum/viewtopic.php?t=1150&p=42886#p42886 <![CDATA[Re: Hello from central NJ]]> Statistics: Posted by Javidrifter — Fri Oct 29, 2021 12:39 am
2020-10-05T20:35:46 2020-10-05T20:35:46 https://rusefi.com/forum/viewtopic.php?t=1150&p=38046#p38046 <![CDATA[Re: Hello from central NJ]]>
I'm in Middlesex county
Oh your are only a few miles away from three of us here in NJ :)
Are you still playing with the 1985 Toyota corolla GTS or do you have a Miata already? :)
Statistics: Posted by AndreyB — Mon Oct 05, 2020 8:35 pm
2020-07-01T11:36:25 2020-07-01T11:36:25 https://rusefi.com/forum/viewtopic.php?t=1150&p=37276#p37276 <![CDATA[Re: Hello from central NJ]]> Statistics: Posted by Javidrifter — Wed Jul 01, 2020 11:36 am
2017-01-14T03:24:54 2017-01-14T03:24:54 https://rusefi.com/forum/viewtopic.php?t=1150&p=22478#p22478 <![CDATA[Re: Hello from central NJ]]>
ASE master tech, that's cool. I'd bet you can teach us some cool tricks :)
If you have any questions feel free to ask. If you assemble your board, I suggest starting with the 5V regulator first, as well start with the regulator itself first. It's a large chip on the ground plane. That can be a bugger to get hot enough.
Great thanks again I will let you guys know when I get the kit
Statistics: Posted by Javidrifter — Sat Jan 14, 2017 3:24 am
2017-01-13T18:03:15 2017-01-13T18:03:15 https://rusefi.com/forum/viewtopic.php?t=1150&p=22456#p22456 <![CDATA[Re: Hello from central NJ]]>
Statistics: Posted by kb1gtt — Fri Jan 13, 2017 6:03 pm
2017-01-13T16:15:45 2017-01-13T16:15:45 https://rusefi.com/forum/viewtopic.php?t=1150&p=22449#p22449 <![CDATA[Re: Hello from central NJ]]>
My crank trigger / cam position sensor is a hall effect inside of my distributor.
That does remove the requirement of soldering the smallest pitch MAX9926 chip. With Hall Effect sensors I see Frankenso assembled (without secondary USB/TTL chip which you can live without) with only soldering iron and soldering wire.
Statistics: Posted by AndreyB — Fri Jan 13, 2017 4:15 pm
2017-01-13T16:08:30 2017-01-13T16:08:30 https://rusefi.com/forum/viewtopic.php?t=1150&p=22446#p22446 <![CDATA[Re: Hello from central NJ]]>
You need soldering paste & https://www.tindie.com/products/russian/frankenso-04-diy-kit-/
If your position sensors are Hall-effect you can maybe get away without soldering paste. There is that http://rusefi.com/forum/viewtopic.php?f=4&t=425 topic relevant to that.
Statistics: Posted by Javidrifter — Fri Jan 13, 2017 4:08 pm
2017-01-13T15:12:12 2017-01-13T15:12:12 https://rusefi.com/forum/viewtopic.php?t=1150&p=22440#p22440 <![CDATA[Re: Hello from central NJ]]> https://www.tindie.com/products/russian/frankenso-04-diy-kit-/
Statistics: Posted by AndreyB — Fri Jan 13, 2017 3:12 pm
2017-01-13T15:09:22 2017-01-13T15:09:22 https://rusefi.com/forum/viewtopic.php?t=1150&p=22438#p22438 <![CDATA[Re: Hello from central NJ]]>
Where in central NJ are you?
What are your plans?
Welcome to the fun discovery that is rusefi :)
I am interested in the FRankenso, I would like to get the un assembled kit & put one together
I have read through the wiki's several times & decided to start posting my project to get some feed back from the community. I am an ASE master tech with 14 years of experience, also I have been racing cars for 18 years.Hopefully I can be helpful to the community ,I feel building an ECU would be a great learning experience & I'm very excited to get started. :mrgreen:
Statistics: Posted by Javidrifter — Fri Jan 13, 2017 3:09 pm
2017-01-13T10:36:09 2017-01-13T10:36:09 https://rusefi.com/forum/viewtopic.php?t=1150&p=22416#p22416 <![CDATA[Re: Hello from central NJ]]>
Have you found the wiki? Just in case you have not here's a link you might be interested in. http://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_board
Statistics: Posted by kb1gtt — Fri Jan 13, 2017 10:36 am
2017-01-13T04:16:52 2017-01-13T04:16:52 https://rusefi.com/forum/viewtopic.php?t=1150&p=22372#p22372 <![CDATA[Re: Hello from central NJ]]> What are your plans?
Statistics: Posted by stefanst — Fri Jan 13, 2017 4:16 am
2017-01-13T03:06:13 2017-01-13T03:06:13 https://rusefi.com/forum/viewtopic.php?t=1150&p=22371#p22371 <![CDATA[Re: Hello from central NJ]]>
Statistics: Posted by AndreyB — Fri Jan 13, 2017 3:06 am
2017-01-13T03:02:11 2017-01-13T03:02:11 https://rusefi.com/forum/viewtopic.php?t=1150&p=22370#p22370 <![CDATA[Re: Hello from central NJ]]> Welcome ...
Statistics: Posted by Abricos — Fri Jan 13, 2017 3:02 am
2017-01-13T02:40:26 2017-01-13T02:40:26 https://rusefi.com/forum/viewtopic.php?t=1150&p=22369#p22369 <![CDATA[Hello from central NJ]]> Statistics: Posted by Javidrifter — Fri Jan 13, 2017 2:40 am
