rusefi.com The most advanced open source ECU 2017-02-12T16:24:02 https://rusefi.com/forum/app.php/feed/topic/1175 2017-02-12T16:24:02 2017-02-12T16:24:02 https://rusefi.com/forum/viewtopic.php?t=1175&p=23686#p23686 <![CDATA[Re: Accelerometer note]]> https://en.wikipedia.org/wiki/Six_degrees_of_freedom
I guess 9 DOF might use a magnetometer, such that you add North, South, East, West degrees of freedom, or perhaps, pressure for elevation. Or perhaps it is used to describe a articulated robotic arm.
An accelerometer is typically a bit slow to react to changes when rolled on an axis, a Gyroscope allows fast reactions to axial rotation, but have a tendency to drift. An accelerometer with gyroscope allows for fast reactions to axial rotation, and the accelerometer prevents the longer term drift. This MPU-6050 simplifies the process of getting this kind of data and it does it for low $.
Statistics: Posted by kb1gtt — Sun Feb 12, 2017 4:24 pm
2017-02-12T16:06:51 2017-02-12T16:06:51 https://rusefi.com/forum/viewtopic.php?t=1175&p=23684#p23684 <![CDATA[Re: Accelerometer note]]> (discovery datasheet)
btw. what is 9DOF in similar boards?
Statistics: Posted by puff — Sun Feb 12, 2017 4:06 pm
2017-02-12T15:52:57 2017-02-12T15:52:57 https://rusefi.com/forum/viewtopic.php?t=1175&p=23682#p23682 <![CDATA[Accelerometer note]]>
http://www.ebay.com/itm/6DOF-MPU-6050-Module-3-Axis-Gyroscope-Accelerometer-Module-for-Arduino-MPU-6050-/272546609408?hash=item3f750b3900:g:-NwAAOSw44BYlyqp
Statistics: Posted by kb1gtt — Sun Feb 12, 2017 3:52 pm
