[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result rusefi.comThe most advanced open source ECU2017-03-02T22:42:27https://rusefi.com/forum/app.php/feed/topic/11872017-03-02T22:42:272017-03-02T22:42:27https://rusefi.com/forum/viewtopic.php?t=1187&p=24148#p24148To be continued! Koen
Statistics: Posted by K0ENIE — Thu Mar 02, 2017 10:42 pm
]]>2017-03-02T13:22:392017-03-02T13:22:39https://rusefi.com/forum/viewtopic.php?t=1187&p=24132#p24132 The OEM ECUs that I have worked on add fuel enrichment as a second pulse which means that under load they are effectively a batched fired system anyway.
Statistics: Posted by Rhinoman — Thu Mar 02, 2017 1:22 pm
1) could it be an error on the diagram? 2) technically what is wrong with 1+2/3+4 exactly? one way or another we are squirting fuel on the closed valve, probably does not matter THAT much when exactly.
Statistics: Posted by AndreyB — Thu Mar 02, 2017 1:06 pm
]]>2017-03-02T08:19:582017-03-02T08:19:58https://rusefi.com/forum/viewtopic.php?t=1187&p=24126#p24126 The system is full sequential so petrol will be injected on 1-3-4-2 order. The liquid propane injection (Vialle LPE-4) from the same donorcar is semi-sequential (or half-sequential or batched) so fuel will be injected two times in one cycle. In this case 2 cylinders are grouped together and on the wiringdiagram I see cylinder 1+2 and 3+4 are grouped.
