Because it's a "Siamese port" configuration (each cylinder bank consists of two cylinders and share one port+injector), and due to the fact that the paired cylinders on each bank fire right after one another throughout the cycle, there'll be a mismatch of available fuel locally in the intake manifold runner between the two paired cylinders regardless if you inject four evenly spaced pulses simultaneously (AAAA) throughout the engine cycle, or if you spread four injections across the two injectors in an alternating fashion (ABAB - batch).
This is because the leading cylinder out of the two cylinders in each bank will "swallow" all available fuel in the intake port during its intake stroke, and there'll be only one single injection event (1/4 of the needed fuel) before the trailing cylinder in the bank is ready to be filled (in simultaneous mode).
I think one possible way to work around this problem with the current firmware, would be to run fully sequential with a cam sensor, and connect each of the two injectors to two separate injector driver channels in a way so that the typical ABCD-sequence could be translated into an ABBA from the injectors point of view. That way, both cylinders in each bank should be getting the correct amount of fuel, and the actual flow rate of the injector should be used. However, the effective duty% of the injectors will be twice as high as the duty% reported by the ECU whenever the ECU assumes one injector per cylinder.
I think this will be the solution for now until a specific "Siamese port" feature might be added at some later point.
Statistics: Posted by tmbryhn — Sun Jul 23, 2023 9:09 pm
