rusefi.com The most advanced open source ECU 2023-06-27T11:07:46 https://rusefi.com/forum/app.php/feed/topic/2575 2023-06-27T11:07:46 2023-06-27T11:07:46 https://rusefi.com/forum/viewtopic.php?t=2575&p=47927#p47927 <![CDATA[Re: New Engine Support]]>
Engine is of 70cc, 2 stroke, single cylinder, efi based direct injection.
direct injection? that would mean a few pretty heavy capacitors and an ASIC chip at least using existing rusEFI design https://rusefi.com/s/gdi4/
Statistics: Posted by AndreyB — Tue Jun 27, 2023 11:07 am
2023-06-27T11:04:38 2023-06-27T11:04:38 https://rusefi.com/forum/viewtopic.php?t=2575&p=47926#p47926 <![CDATA[Re: New Engine Support]]> https://github.com/rusefi/rusefi/wiki/Case-Studies#2-stroke
You need crank and TPS or crank and MAP to run an engine.
Smallest board I am aware of is https://github.com/ElDominio/ParalelaHardware
https://github.com/rusefi/rusefi/wiki/Standalone-on-Demand is your other option
Statistics: Posted by AndreyB — Tue Jun 27, 2023 11:04 am
2023-06-27T10:08:29 2023-06-27T10:08:29 https://rusefi.com/forum/viewtopic.php?t=2575&p=47925#p47925 <![CDATA[New Engine Support]]> I am creating a custom ECU and analysing if rusefi can be used for this purpose or not. Following is my custom engine specification:
Engine is of 70cc, 2 stroke, single cylinder, efi based direct injection. I have following queries regarding to the rusefi:
1. Does rusEFI supports 2 stroke engine
2. What all minimum sensors does rusEFI needs to operate the engine in a correct matter.
Thanks in Advance.
Statistics: Posted by devchandil — Tue Jun 27, 2023 10:08 am
2023-06-27T07:04:41 2023-06-27T07:04:41 https://rusefi.com/forum/viewtopic.php?t=2575&p=47924#p47924 <![CDATA[New Engine Support]]>
I am trying to build an ECU for a 70cc, 2 stroke engine, single cylinder custom engine. I have following query regarding to the use of rusefi in this particular matter:
1. Does rusEFI supports 2 stroke engine?
2. What are the minimum sensor requirement to utilise rusEFI in order to control the said engine?
Statistics: Posted by devchandil — Tue Jun 27, 2023 7:04 am
