I swapped the 1.8t engine coded audi tt mk1 ARY to my old golf 2 car. I did the sensor wiring myself. I connected the injector and ignition coils. Now the electronic accelerator pedal and ETB are working properly. I can read data from sensors. I try to make basic adjustments and start. But I couldn't start the engine. There is a lambda sensor and a map, but only the map is currently connected. I will also connect the lambda. I could not complete the pipe for the map, so the map is in the open air.I connected the fuel pump to the relay. It works when I turn on the ignition, and it activates and continues to work when cranking.The injectors and ignition coils work when I test them.I've been reading and researching how to make timing adjustments, but I'm confused. I have no experience on the subject, I'm trying to do it by researching and following forums.I couldn't find a base map and I couldn't find a configuration file I could look at as an example. How should I configure the trigger and is there an example configuration file I can take a look at? Could the fact that I did not connect the turbo be the reason for it not working? I bought it without knowing the condition of the engine. Right now I just want to start the engine to test it. I will add new updated photos, these are old photos.
Tune file https://rusefi.com/online/download.php?msq=1673
Our parts:
induvisual bosch R8 coil
Fuel injector 06A 906 031 BC flow Rate: Approximately 317cc/min at 3 bar fuel pressure
CLT sensor
IAT sensor
HALL cam
Cranck VR 60-2 toothStatistics: Posted by mfurkanates — Mon Jun 17, 2024 9:27 am
