rusefi.com The most advanced open source ECU 2025-02-12T17:47:35 https://rusefi.com/forum/app.php/feed/topic/2787 2025-02-12T17:47:35 2025-02-12T17:47:35 https://rusefi.com/forum/viewtopic.php?t=2787&p=50407#p50407 <![CDATA[Re: JEEP 4.0 Success - UAEFI]]> UPDATE: I have updated the tune file. After a few seasons of driving the Jeep, I have moved to open loop idle, fixed some ignition timing errors, adjusted cold start settings, and probably some other adjustments. I have been enjoying this tune for a few months now.
Statistics: Posted by scfrontier — Wed Feb 12, 2025 5:47 pm
2024-09-01T17:27:10 2024-09-01T17:27:10 https://rusefi.com/forum/viewtopic.php?t=2787&p=49886#p49886 <![CDATA[Re: JEEP 4.0 Success - UAEFI]]> Statistics: Posted by mpgmike — Sun Sep 01, 2024 5:27 pm
2024-09-01T10:03:55 2024-09-01T10:03:55 https://rusefi.com/forum/viewtopic.php?t=2787&p=49881#p49881 <![CDATA[Re: JEEP 4.0 Success - UAEFI]]> Statistics: Posted by mpgmike — Sun Sep 01, 2024 10:03 am
2024-07-28T01:42:20 2024-07-28T01:42:20 https://rusefi.com/forum/viewtopic.php?t=2787&p=49762#p49762 <![CDATA[Re: JEEP 4.0 Success - UAEFI]]> Cylinder 1 = B6
2 = B5
3 = B4
4 = B3
5 = B2
6 = B1
Statistics: Posted by scfrontier — Sun Jul 28, 2024 1:42 am
2024-07-27T16:36:29 2024-07-27T16:36:29 https://rusefi.com/forum/viewtopic.php?t=2787&p=49757#p49757 <![CDATA[Re: JEEP 4.0 Success - UAEFI]]> 20240727_113304.jpg
Statistics: Posted by scfrontier — Sat Jul 27, 2024 4:36 pm
2024-07-24T00:46:04 2024-07-24T00:46:04 https://rusefi.com/forum/viewtopic.php?t=2787&p=49735#p49735 <![CDATA[Re: JEEP 4.0 Success - UAEFI]]> 20230304_211149.jpg
Statistics: Posted by scfrontier — Wed Jul 24, 2024 12:46 am
2024-07-23T03:11:28 2024-07-23T03:11:28 https://rusefi.com/forum/viewtopic.php?t=2787&p=49733#p49733 <![CDATA[Re: JEEP 4.0 Success - UAEFI]]>
Thank you for the warm words and the amazing write up!
Statistics: Posted by AndreyB — Tue Jul 23, 2024 3:11 am
2025-02-12T17:40:28 2024-07-22T20:38:07 https://rusefi.com/forum/viewtopic.php?t=2787&p=49731#p49731 <![CDATA[JEEP 4.0 Success - UAEFI]]> Tune file: https://rusefi.com/online/view.php?msq=1729
This Jeep is a 1984 CJ7 with a 4.0 out of a 98 Grand Cherokee. When my father acquired the Jeep sometime in the 90's, it had a 4.2L carbureted engine and a soft top. It had no a/c, a few distasteful modifications (hammered hole in firewall, drilled holes), but was in pretty good shape.
Fastforward 30 years, and now he has given the Jeep to me. The first thing I wanted to do was address the engine, engine bay, and clutch.
After some research I discovered the newer 4.0 engine was pretty much a direct bolt in replacement (at least bell housing, motor mounts, clearance), so a running junk yard engine was purchased. That engine was rebuilt using stock specified components, and the bell housing was modified for a crank position sensor. The original transmission (nwc T5) only needed an adapter pilot bushing to be installed in the crankshaft. For the ignition system I went with a three coil (wasted spark style) coil pack and added a coil driver to it. The fuel system is stock except for a fuel pressure regulator mounted to the intake manifold. The clutch was converted to hydraulic using oem style parts for a four-cylinder cj7 (custom length slave-to-fork engagement rod). The stock A/C compressor was adapted to a Jeep Air under dash unit (works great).
Things I am not asking the ecu to do:
  • directly drive the alternator field coil. I'm using a big solid state relay under the ECUs control.
  • control wideband O2 sensor. I had already installed a 14Point7 device.
  • control a/c compressor. Engine idles up when the compressor turns on because it reads coil state. I added a diode on the compressor coil for extra safety.
Overall impression
I am quite impressed with how the engine runs and its street mannerisms. A/c idles up, manual shifts are smooth thanks to "dashpot" settings, deacceleration-to-stop is smooth, acceleration is crisp and responsive, and cold start is quick. The previous ecu was a MS3, but unfortunately, I damaged the circuit board, and it was cost prohibitive to replace. For a much cheaper price I got the UAEFI (ultra affordable efi). Not only is the UAEFI smaller, it has all the features I need (plus more), required no hardware modifications, and is cheaper to replace if I make a major wiring mistake. Furthermore, I can research and/or modify every feature of the device using the open source code bank.
The Jeep project chapter may be closing for me, but with so much power for so little money, I see a lot more projects in the future!
Statistics: Posted by scfrontier — Mon Jul 22, 2024 8:38 pm
