rusefi.com The most advanced open source ECU 2025-10-03T02:30:15 https://rusefi.com/forum/app.php/feed/topic/2978 2025-10-03T01:41:48 2025-10-03T01:41:48 https://rusefi.com/forum/viewtopic.php?t=2978&p=50961#p50961 <![CDATA[Re: 1997 Camry 5SFTE on UAEFI, first start]]> This should be "close" enough.
Statistics: Posted by jmhalder — Fri Oct 03, 2025 1:41 am
2025-10-03T01:37:54 2025-10-03T01:37:54 https://rusefi.com/forum/viewtopic.php?t=2978&p=50960#p50960 <![CDATA[Re: 1997 Camry 5SFTE on UAEFI, first start]]> Statistics: Posted by AndreyB — Fri Oct 03, 2025 1:37 am
2025-10-03T02:30:15 2025-10-03T01:29:18 https://rusefi.com/forum/viewtopic.php?t=2978&p=50959#p50959 <![CDATA[Re: 1997 Camry 5SFTE on UAEFI, first start]]>
I haven't bothered switching the tach wire from the 6th ignition output to the 6th injector output (with a pull-up) yet. I did notice that my VE values are seemingly far too high. I have e85 in the car, and it was testing ~70% ethanol when it was parked with the Microsquirt. I haven't wired the Flex sensor yet, so I set the Stoichiometric ratio to 10.7:1. The VE map isn't really "tuned" yet, but pretty sane values below 100kpa seem to exceed 100 for VE. I have the injectors set at 300kpa/550cc (they're out of a late model WRX, people often refer to them as 565cc or 550cc). It IS returnless and set for "fixed pressure". It feels like either the fixed pressure, or 10.7:1 stoich are what is causing the issue. I still am tuning for 14.7:1 scale in the target map, which I believe is "fine" even if switching the project to lambda is "best practice"
I've included my VE map that's been touched only by autotune, I started with a AI VE map from the AlphaX site, since I was going to auto-tune 75% of it anyways, and multiplied it by 1.4x, since idle needed about 1.4x to be happy. Also, I got my uaDash hooked up, I did turn on the 120ohm resistor on the Waveshare display, but didn't hook up a resistor on the UAEFI, and it still works fine. Should I bother with a 120ohm resistor there?
iframe
Link to the msq if anyone wants to help whatever is causing me to require higher VEs:
(ignore that my timing is fixed here, I forgot to change it back after double checking my timing with a timing light)
https://drive.google.com/file/d/19tBg_Pep4lCEgHYjVou6rfz5oeP5FU3W/view?usp=sharing
Statistics: Posted by jmhalder — Fri Oct 03, 2025 1:29 am
2025-09-29T20:57:33 2025-09-29T20:57:33 https://rusefi.com/forum/viewtopic.php?t=2978&p=50916#p50916 <![CDATA[Re: 1997 Camry 5SFTE on UAEFI, first start]]> https://github.com/rusefi/rusefi/wiki/Trigger-Configuration-Guide#determine-correct-polarity
Statistics: Posted by AndreyB — Mon Sep 29, 2025 8:57 pm
2025-09-28T19:01:59 2025-09-28T19:01:59 https://rusefi.com/forum/viewtopic.php?t=2978&p=50914#p50914 <![CDATA[1997 Camry 5SFTE on UAEFI, first start]]> Got it to start, but crank and cam signals are literally a guess for polarity.
iframe
Statistics: Posted by jmhalder — Sun Sep 28, 2025 7:01 pm
