rusefi.com The most advanced open source ECU 2025-10-11T07:22:56 https://rusefi.com/forum/app.php/feed/topic/2993 2025-10-11T07:22:56 2025-10-11T07:22:56 https://rusefi.com/forum/viewtopic.php?t=2993&p=50998#p50998 <![CDATA[Re: 740 Turbo]]>
I had connected the activation for my main relay and fuel pump relay to B9 Main Relay Weak Low Side Output 1 and B16 Low Side Output 4 / Fuel Pump Relay, but when I looked at the car’s original wiring diagram, those are supposed to be grounded, not receive a control voltage.
Yet the relays still clicked on, so I’ve probably managed to damage something.
Statistics: Posted by turbomuts — Sat Oct 11, 2025 7:22 am
2025-10-08T20:40:40 2025-10-08T20:40:40 https://rusefi.com/forum/viewtopic.php?t=2993&p=50985#p50985 <![CDATA[Re: 740 Turbo]]> Statistics: Posted by Dron_Gus — Wed Oct 08, 2025 8:40 pm
2025-10-08T14:04:34 2025-10-08T14:04:34 https://rusefi.com/forum/viewtopic.php?t=2993&p=50983#p50983 <![CDATA[Re: 740 Turbo]]> Statistics: Posted by turbomuts — Wed Oct 08, 2025 2:04 pm
2025-10-08T13:52:46 2025-10-08T13:52:46 https://rusefi.com/forum/viewtopic.php?t=2993&p=50982#p50982 <![CDATA[Re: 740 Turbo]]> Statistics: Posted by AndreyB — Wed Oct 08, 2025 1:52 pm
2025-10-08T12:34:55 2025-10-08T12:34:55 https://rusefi.com/forum/viewtopic.php?t=2993&p=50980#p50980 <![CDATA[740 Turbo]]>
With Rusefi, I’m trying to keep it as plug-and-play as possible with such an old ECU setup like LH2.4. In the PnP harness, I’m using the functions for controlling the ignition box, all relays such as the fuel relay, etc. I’ve also wired in the engine temperature sensor and the VR signal from my 60-2 flywheel. However, that stopped working — I’m getting a lot of missing teeth, so I’ll try running separate wires to it, like I already did with the MAP sensor, IAT, and TPS.
I’m afraid I may have damaged the board when I cleaned off the flux residue I missed after soldering the Molex connectors on the board using isopropanol. After that, I started getting interference on the VR signal, and I also get the message “C9012: out-of-order coil of coil 1” in the Rusefi console. I even get that error when I run a spark test in the console with only the Uaefi board connected to the computer.
Statistics: Posted by turbomuts — Wed Oct 08, 2025 12:34 pm
