rusefi.com The most advanced open source ECU 2015-03-10T04:15:25 https://rusefi.com/forum/app.php/feed/topic/842 2015-03-10T04:15:25 2015-03-10T04:15:25 https://rusefi.com/forum/viewtopic.php?t=842&p=14550#p14550 <![CDATA[Re: Combustion gas detection]]>
If you apply pressure to a cylinder, the cooling system is full, and you get bubbles in the radiator, you have a problem.
Statistics: Posted by abecedarian — Tue Mar 10, 2015 4:15 am
2015-03-09T22:30:15 2015-03-09T22:30:15 https://rusefi.com/forum/viewtopic.php?t=842&p=14545#p14545 <![CDATA[Re: Combustion gas detection]]>
I have compression test tools, and I should be able to modify them to do a leak down test. I'll have to get something to measure the radiator pressure. I seem to recall you can get a replacement plug thing for the rad cap which can allow a standard hose fitting.
Oh the joys of crappy vehicles.
Statistics: Posted by kb1gtt — Mon Mar 09, 2015 10:30 pm
2015-03-09T20:40:39 2015-03-09T20:40:39 https://rusefi.com/forum/viewtopic.php?t=842&p=14544#p14544 <![CDATA[Re: Combustion gas detection]]>
If so, pressurizing the cylinders while monitoring the pressure in the cooling system will let you know right quick if the head gasket, cracked head or cracked block are an issue.
Statistics: Posted by abecedarian — Mon Mar 09, 2015 8:40 pm
2015-03-09T10:55:54 2015-03-09T10:55:54 https://rusefi.com/forum/viewtopic.php?t=842&p=14536#p14536 <![CDATA[Combustion gas detection]]> https://www.google.com/shopping/product/13190523127613337511?biw=1280&bih=642&q=combustion+gas+tester&bav=on.2,or.&bvm=bv.87611401,d.eXY&ion=1&espv=2&tch=1&ech=1&psi=B2z9VIubBIurNqasgIAG.1425894406446.17&prds=paur:ClkAsKraX81q96W34Wq4yFrEP84N-nFyAwMeUzDfG8oBJr0L62fKfCawx-L2atxFikv97oIEZjUWIs3Cp-xdOjQj8LIPm0oIL-CRFaJyITomCq_90QcJGiGv0RIZAFPVH719FDm9qflouEOpLThYq0rFacJdJA&ei=sG79VNDhG4fegwSHq4DYDQ&ved=0CHQQpiswAA
While that is good for a low cost shop use situations, the chemicals are kind of a blah to deal with. Who knows how to dispose of them or if they are carcinogens? Do the chemicals go stale over time? What happens if the fluid freezes? ect. So I looked for some electronic versions of a combustion sensor, and found a price range that's commonly between a couple hundred dollars, to thousands of dollars. Such an option would be handy for shop use, but I wonder, what happens when people use those liquid head gasket repairs, which may patch a combustion breach for a period of time. It would be handy to have something I can install in the vehicle for a prolonged period of time and sense an intermittent combustion to radiator leak.
I found this ITEAD sensor, and I'm tempted to find a way to add this sensor to the vent line on the radiator in a used vehicle I own. ftp://imall.iteadstudio.com/Electronic_Brick/IM120710024/DS_IM120710024.pdf
The used vehicle I have may or may not have had some liquid head gasket repair added to the coolant. I know it has intermittent overheating issues. I think this kind of tool would allow me to isolate the problem. Does anyone have any thoughts about if such a sensor could play nice or be of any use in this kind of detection?
Statistics: Posted by kb1gtt — Mon Mar 09, 2015 10:55 am
