Msdroid Bluetooth connection
For some unknown reason Msdroid don't recognize rusEFI ini, I think might have something to relate to the fact that it have a space character, anyway reported to dev and he nicely will add ini to his server , so it will automatically download on connection
- Screenshot_2020-01-24-19-47-03-142_com.google.android.gm.jpg (585.12 KiB) Viewed 12825 times
Re: Msdroid Bluetooth connection
There is a special identifier in the packets that are sent back and forth with TS and rusEFI. I know rusEFI has it's own identifier while MS has their own identifier. This is likely an issue for MSDroid. I recall the INI file has that identifier in plain text, so once they see that part of the INI file, they will probably have it all squared away.
Hi , im back at testing stuff and BT was someting i realy wanted i found a simple fix: create a [Megatune] and place the signature inside, dosen't afect how TS conects to it but like so is poosible to conecto to msdroid.
already talked to MSdroid dev and asked why it would´t search there.
Please be more specific. Create "[Megatune]" where? Can you paste a screenshot of the changed file? Can you post the complete changed block exactly?
; settingOption = DEFAULT, "Speed Density" ; DEFAULT will be over looked and this will fall into the #else block of the statement.
[MegaTune]
signature = "rusEFI v1.2020.3" ; signature is expected to be 7 or more characters.
[TunerStudio]
queryCommand = "S"
versionInfo = "V" ; firmwave version for title bar.
[Constants]
[MegaTune]
[TunerStudio]
queryCommand = "S"
[Constants]
- Screenshot_2020-04-15-21-41-30-756_com.msdroid.jpg (175.75 KiB) Viewed 11135 times
thank you!
i've just added those lines this into official file, will appear in bundle later today
I've got a Hellen NB1 ECU with HC06 and I'm having the same issue you did originally. How did you fix this to get it working with MSdroid? I just get the "definition unavailable" error although I've even tried putting the correct INI file into the MSDroid/ini folder on my phone. Cheers
- Screenshot_2021-11-11-21-05-53.png (1.34 MiB) Viewed 7256 times
