[help needed] stock bins of Ford Excursion 2000-2003 or later (6.8L V10 or diesel)
habana_nirvana
Post by habana_nirvana »
I'm looking into doing an electronics project that allows me to build something (OBD scanner) while also Reverse Engineer bin files so to access the lookup tables and then parameters so I can do a live analysis of data when plugged in (or at least having a bin file).
I'm looking into RE-ing bins of Ford excursion (6.8L and diesel, 2000-2003 mainly, but would love any other years).. I assume they would use the intel 8065 microprocessor and MTC-422 ECU hardware for 6.8L.
I'm also assuming that the F-series super duty F250 and F350 of those years share the same ECUs.
If you happen to have these bin files on hand I would love to RE them or even help maintain the driveability of your car!
Thanks!
Simon@FutureProof
Slack: Orchardperformance
Re: stock bins of Ford Excursion 2000-2003 or later (6.8L V10 or diesel)
Post by Simon@FutureProof »
I have moved this to the misc forum as while there may be someone here who can help and we love this kind of freeing of knowledge the topic is not really directly about the rusEFI software.
