Random harley info
Posted: Fri Oct 15, 2021 8:19 pm
Re: Random harley info
Posted: Fri Oct 15, 2021 8:38 pm
plugs for 2012-2020
black 4-2203663-4
https://www.te.com/usa-en/product-4-2203663-4.html
18 pin
grey 6-2203663-2
https://www.te.com/usa-en/product-2203663-6.html
same 18 pin
brown 6-2203663-6 - headlight connector on a buick :)
same 18 pin
2021 is different, single connector
Posted: Fri Oct 15, 2021 8:55 pm
by nmstec
I also have personal information on what sensors & shit run on it, as I had to wire these piles up.
Posted: Sat Oct 16, 2021 2:31 am
Mark, while your pictures obviously show TE part numbers, that weird photo from the internet says Delphi
Searching for 18 pin Delphi gives us https://mechanics.stackexchange.com/questions/29993/which-18-pin-automotive-connector-is-this
Delphi 13658062 Delphi 13658063 Delphi 13699658
Also legacy TE 1488533-5 1488533-6
Also Ford WPT-1411 and CU2Z14S411GB
Russian internet tells us that Ford and GM used same adaptive cruise control module KJ7TT-9G768-AC which uses this 18 pin header but again in molded form
Posted: Sat Oct 16, 2021 3:02 am
DJ7181A-1.5-21/11 is the search criteria for aliexpress
which gets us JAE part numbers MX23A18SF1 and MX23A18NF1
Posted: Sun Oct 17, 2021 12:57 pm
by mk e
I've not kept up on new stuff but for sure the older stuff used a delphi ECU, from a GM V6 iirc. There was a crank sensor but no cam position.....but they were full sequential. They had ion knock sensing and have very uneven firing (315 degrees then 405) as they use a common pin crank and a 45degree V is possible to tell which cylinder is firing by either crank speed or the knock sense...I don't know which they used. No idea what they are doing these days.
Posted: Mon Oct 18, 2021 12:00 am
by nmstec
The ones I'm working with are mostly 2015+
They have dual knock sensors, non-ion sensing coils, crank & cam, still same stupid firing sequence. One of our motors is coming apart anyway for upgrades, will take more detailed pics of crank and cam pickups.
Have some pics below:
Posted: Mon Oct 18, 2021 2:14 am
by mk e
I was getting out just as the ECUs were coming in and lost touch....I used to roadrace an XR...with carbs :)
