ELI5 truck diesel engines
Posted: Sat Feb 11, 2023 4:49 pm
Let's assume I understand 2006 Volkswagen Passat GDI system as in with cam-driven HPFP and 65 volts boosted peak-and-hold solenoid injectors.
Based on 2006 2.0T Passat understanding what do diesel trucks use?
Do they have fully mechanical HPFP or does ECU play any role on HPFP control?
Do the all? Some? Many? Most? have "normal" 12v (or 24v?) high-z injectors or do they have peak-and-hold with boosted voltage injection?
Is there any technical difference between CRI and CRD or is it both the same https://en.wikipedia.org/wiki/Common_rail?
