1N: IDL for stock sensor
2D: GND for stock sensor (GND_SENS)
2L: WOT for stock sensor (why is this not connected on the MRE48?)
For stock, 1N and 2L will all be pulled up by the ECU, so they will be grounded at different depression levels. When the TPS is between IDL and WOT, 2L and 1N will all be "HIGH".
For the vTPS, since the center pin is still GND, it should still be pulled up by R22, so R22 should NOT be removed.
Basically what I see is that no schematic change is necessary. However the schematic notes say I should remove R22.
@stefanst Could you explain what is actually happening? Thanks a lot in advance
