[help needed] I want to use MicroRusEFI on my motorcycle
linx
Post by linx »
But only the crankshaft sensor, without the camshaft sensor, I was able to run the engine using the "waste spark" ignition mode
Encountering a problem: Sometimes the engine stalls when the accelerator is turned on while idling (even if the fuel injection quantity is increased), but sometimes it is normal. I suspect that MicroRusEFI did not correctly recognize the intake stroke for fuel injection. I also have an intake pressure sensor. How can I fix this situation?
ps: My native language is not English, and the translation software may not express myself clearly. Sorry
linx
Re: I want to use MicroRusEFI on my motorcycle
Post by linx »
Perhaps my question was not very accurate. What I asked was, can I use MicroRusEFI on my motorcycle with only the crankshaft sensor
Yes, you can
You can also sync by MAP for better results
linx
Post by linx »
Thu Dec 26, 2024 1:08 pm
Yes, you can
Thank you very much for your reply. I successfully solved the problem of engine stalling when turning the throttle by using "Fuel Strategy" ->"alpha-N" in the "Engine Basic Settings". My engine is already running (although its working condition may not be very good). Now I have two questions need to ask:
1: Why can the engine run? I only have one 24-1 crankshaft sensor. How does MicroRusEFI recognize the intake stroke and perform fuel injection? I used the 'waste spark' ignition mode and observed that the fuel injection in 'rusefi_comsole' was only executed once;
2: I am using the 20241117 version of rusEFI, and I haven't seen where I can set up the use of map for synchronization yet
Sorry, I am a beginner and have many questions to ask
mk e
Post by mk e »
1) Its ony 1/2 sync with only a crank trigger so you need batch fuel I think and that should give fuel every revolution.
2) MAP sync is in the cam signal settings
then just guessing be sure and set this to a rpm that you will have a good MAP signal...MAP goes away at WOT
and probably this so it will start before its spinning fast enough to be pulling good vacuum. good luck!
linx
Post by linx »
mk e wrote:
Fri Dec 27, 2024 6:24 pm
Thank you so much !!!!
