VE & Ignition blend tables with RPM too low axis value
Posted: Tue Dec 10, 2024 4:13 pm
The VE and ignition blend table allows RPM as the blend parameter but have a max value limit of 1000 on the axis, so too low for most RPM based uses. There was talk of bigger VE table on discord and the thought was the blend table could be used to effectively add additional rpm points....but the axis limit is too low use rpm selection for anything but crank/idle. Looks like the Ignition blend is the same limit
