[info] Double map
Gianvito90
Double map
Post by Gianvito90 »
Hi guys, I noticed that compared to Megasquirt it doesn't have the dual map option activated by switch or hardware or anything else. Or am I wrong? Also, is there the possibility of using dual injectors so as to have 4 work at low revs and the other 4 or all 8 at high revs?
Re: Double map
Gianvito90
Re: Double map
Thanks. Today I was playing with Tuner Studio and found all the answers to my questions. I noticed that you can set the percentage of the two injector trains, or the ECU simply turns off the first ones and turns on the second ones based on the duty cycle limit set previously. I'll ask more questions in new posts so that other users can quickly find the answers.
Re: Double map
Gianvito90 wrote:
Wed Oct 01, 2025 4:20 pm
Please attempt to find answers in TS or wiki.
