VE Table Blending for ITB: "Multiply MAP" and "SD --> a/n"?
Dominik335i
Post by Dominik335i »
Hello everyone,
I have a few newbie questions and hope for your support: So far, I've converted several engines to Megasquirt and Speeduino. I'm toying with the idea of ​​switching my own Caterham's platform from Speeduino to Rusefi. Why? It's an NA engine with very high specific power (240hp from a 1.8 l), ITBs (specifically, roller barrels) and quite extreme camshafts.
I'm speculating on improvements in the low-load range through table blending, but unfortunately I don't fully understand the system and can't find any documentation or examples.
Question 1:
I'm currently using "Alpha/n multiply MAP." This means that the VE is simply multiplied by the MAP value to achieve better and "smoother" load sensing at lower TPS: e.g., 70 kPa means VE x 0.7 --> the VEs therefore get larger. At full load (~100 kPa), VE x 1 = no effect.
How can this be replicated in Rusefi? Is option 1 or 2 correct (see screenshots)?
Question 2:
Is it possible to completely "blend" from speed density to alpha/n? What would the corresponding tables look like?
Bye
Dominik
