trouble waking up Rusefimicro [resolved, soldering issue]
Posted: Thu Oct 13, 2022 6:47 pm
Hi all,
Thanks for letting me join.
2 years ago i bought 2 rusefi micros to play around with. Got them, assembled the remaining bits, put in firmware and done..
Until this year i found a nice task for one of them, controlling a 2 cyl twin air engine on a test stand.
Did all the wiring needed to let it work (except for a redundant Accelerator Pedal). Made all the settings with it connected to USB, and then put it online. None of my outputs worked, sensors got no 5V at all and it was pretty much non operational, except for the Electronic Throttle body.
Tried the next day, and its totally dead on the test stand until ik plug in the USB. It wakes up, i hear the ETB start its typical Whine and its Run light is lid. Pull the USB and its dead again.
So i took it of the test stand and put 12v and ground on it on my bench. Dead as it can be. No lights, nothing. No3.3V or 5V..
Got 12V on pin 53 and 54. Key has 12V, but it remains in sleep as it seems.
Only voltage that is there is the 5Vstandby from the TL8888.
SO i thought i did something wrong with this one, and took the other controller. Same issue. Dead until USB is there. But then no Outputs or 5V.
I have no idea where i should start. It seems like the TL8888 wont wake up and start producing voltages. Could be that its dead.. But 2 boards with faulty onces? Unless there was a bad batch, i have no explanation.
Anyone who ever come across this issue?
Thanks
Thanks
