rusefi.com • microRusEFI 12v high side output?
Posted: Mon Feb 13, 2023 2:40 pm
by MadGoatCustoms
I need a 12v output to control my fuel pump relay. I have microRusEFI v0.5.4. I found JP2 for switching high side level from 5v to 12v. What else needs to be done?
Re: microRusEFI 12v high side output?
Posted: Mon Feb 13, 2023 2:51 pm
You should be good for low current relay control, not direct pump control.
Posted: Mon Feb 13, 2023 3:23 pm
by MadGoatCustoms
Yes, it is working now. So JP2 setting affects all GP outputs 1 thru 6? Ignition outputs are always 5v regardless, correct?
Posted: Mon Feb 13, 2023 3:24 pm
I believe that JP2 only affects two outputs
Posted: Mon Feb 13, 2023 3:25 pm
yep, exactly like https://rusefi.com/docs/pinouts/microrusefi/ spells it out
Posted: Mon Feb 13, 2023 5:58 pm
by MadGoatCustoms
Thanks for that pinout diagram, in all my searching I never saw that, I've been going by the one on github which doesn't say anything about which pins are high low or push-pull.
Posted: Mon Feb 13, 2023 6:13 pm
Posted: Tue Feb 14, 2023 12:52 am
by MadGoatCustoms
This is the pinout I have been using https://github.com/rusefi/rusefi/wiki/Hardware-microRusEFI-wiring
The problem is that it doesn't name the output types. It describes the different types of outputs, and says which pins are outputs, but it doesn't say which pin is what type (gp_low vs gp_high), they are all just called GP. It's not wrong, it's just incomplete.
Posted: Tue Feb 14, 2023 1:24 am
