Gettting the following
Console version 20250615
Windows 10 10.0
Bundle BundleInfo{branchName='master', target='uaefi'}
Windows 10 10.0
Suspending port scanning...
Port scanning is suspended.
Connecting to port `COM8`...
Performing action on port COM8...
Received a signature rusEFI master.2025.06.05.uaefi.3565673735
Page size is 23804
Reading current calibrations...
Backing up current ini-file `C:\Users\...\.rusEFI\ini_database\3565673735.ini`...
`3565673735.ini` ini-file is backed up as `state/2025-33-12-11.33.53_prev_calibrations.ini`
Backing up calibrations to files `state/2025-33-12-11.33.53_prev_calibrations.zip` and `state/2025-33-12-11.33.53_prev_calibrations.msq`...
Calibrations are backed up to files `state/2025-33-12-11.33.53_prev_calibrations.zip` and `state/2025-33-12-11.33.53_prev_calibrations.msq`
Resuming port scanning...
Port scanning is resumed.
Using selected COM8
Reboot command [reboot_dfu] sent into serial=COM8!
Giving time for USB enumeration...
Executing command=wmic path win32_pnpentity where "Caption like '%STM32%' and Caption like '%Bootloader%'" get Caption,ConfigManagerErrorCode /format:list
Caption=STM32 BOOTLOADER
ConfigManagerErrorCode=0
Caption=STM32 BOOTLOADERConfigManagerErrorCode=0
Executing command=.\STM32_Programmer_CLI/bin/STM32_Programmer_CLI.exe -c port=usb1 -w "C:\RusEFI\console\..\rusefi.bin" 0x08000000 -v -s
STM32CubeProgrammer v2.18.0
USB speed : Full Speed (12MBit/s)
Manuf. ID : STMicroelectronics
Product ID : STM32 BOOTLOADER
SN : 315633663333
DFU protocol: 1.1
Board : --
Device ID : unknown
Warning: Device is under Read Out Protection or Target is held under reset
Error: a read Operation failed, please check if any memory protection mechanism is active.
ERROR: does not look like DFU has worked!
Devices: OK USBDevice STM32 BOOTLOADER USB\VID_...
556 / 0
hint: error state is already in your clipboard, please use PASTE or Ctrl-V while reporting issues
Problem updating firmware on new uaEFI
Re: Problem updating firmware on new uaEFI
At least two things are happening here:
* just improved https://github.com/rusefi/rusefi/issues/8286 try again in 15 minutes once new snapshot is build
* I do not have an explanation for https://github.com/rusefi/rusefi/issues/8287
Seemed to default to DFU again and failed. So I manually selected OpenBLT and it seemed to update but then got errors at the end, including a java error.
Thanks for the help
Console version 20250713
Windows 10 10.0
Bundle BundleInfo{branchName='development', target='uaefi'}
Windows 10 10.0
Page size is 23804
`3565673735.ini` ini-file is backed up as `state/2025-25-13-08.25.58_prev_calibrations.ini`
Backing up calibrations to files `state/2025-25-13-08.25.58_prev_calibrations.zip` and `state/2025-25-13-08.25.58_prev_calibrations.msq`...
Calibrations are backed up to files `state/2025-25-13-08.25.58_prev_calibrations.zip` and `state/2025-25-13-08.25.58_prev_calibrations.msq`
Using selected COM8
Reboot command [reboot_openblt] sent into serial=COM8!
Waiting for ECU on port COM8 (ECU w/ BL) to reboot to OpenBlt for up to 60 seconds.............
Waiting for new OpenBlt port to appear...............................
Serial port COM9 appeared, programming firmware...
flashSerial ..\rusefi_update.srec
Phase: Load firmware file
Phase: Start session
Phase: Erase
Progress: 5%
Progress: 10%
Progress: 15%
Progress: 20%
Progress: 25%
Progress: 30%
Progress: 35%
Progress: 41%
Progress: 46%
Progress: 51%
Progress: 56%
Progress: 61%
Progress: 66%
Progress: 71%
Progress: 77%
Progress: 82%
Progress: 87%
Progress: 92%
Progress: 97%
Progress: 100%
Phase: Program
Progress: 0%
Progress: 1%
Progress: 2%
Progress: 3%
Progress: 4%
Progress: 5%
Progress: 6%
Progress: 7%
Progress: 8%
Progress: 9%
Progress: 10%
Progress: 11%
Progress: 12%
Progress: 13%
Progress: 14%
Progress: 15%
Progress: 16%
Progress: 17%
Progress: 18%
Progress: 19%
Progress: 20%
Progress: 21%
Progress: 22%
Progress: 23%
Progress: 24%
Progress: 25%
Progress: 26%
Progress: 27%
Progress: 28%
Progress: 29%
Progress: 30%
Progress: 31%
Progress: 32%
Progress: 33%
Progress: 34%
Progress: 35%
Progress: 36%
Progress: 37%
Progress: 38%
Progress: 39%
Progress: 40%
Progress: 41%
Progress: 42%
Progress: 43%
Progress: 44%
Progress: 45%
Progress: 46%
Progress: 47%
Progress: 48%
Progress: 49%
Progress: 50%
Progress: 51%
Progress: 52%
Progress: 53%
Progress: 54%
Progress: 55%
Progress: 56%
Progress: 57%
Progress: 58%
Progress: 59%
Progress: 60%
Progress: 61%
Progress: 62%
Progress: 63%
Progress: 64%
Progress: 65%
Progress: 66%
Progress: 67%
Progress: 68%
Progress: 69%
Progress: 70%
Progress: 71%
Progress: 72%
Progress: 73%
Progress: 74%
Progress: 75%
Progress: 76%
Progress: 77%
Progress: 78%
Progress: 79%
Progress: 80%
Progress: 81%
Progress: 82%
Progress: 83%
Progress: 84%
Progress: 85%
Progress: 86%
Progress: 87%
Progress: 88%
Progress: 89%
Progress: 90%
Progress: 91%
Progress: 92%
Progress: 93%
Progress: 94%
Progress: 95%
Progress: 96%
Progress: 97%
Progress: 98%
Progress: 99%
Progress: 100%
Update completed successfully!
Phase: Cleanup
Failed to connect to port COM8 in a minute
Failed to back up updated calibrations...
Thanks for the help
Windows 10 10.0
Windows 10 10.0
Page size is 23804
Using selected COM8
Phase: Erase
Progress: 5%
Progress: 10%
Progress: 15%
Progress: 20%
Progress: 25%
Progress: 30%
Progress: 35%
Progress: 41%
Progress: 46%
Progress: 51%
Progress: 56%
Progress: 61%
Progress: 66%
Progress: 71%
Progress: 77%
Progress: 82%
Progress: 87%
Progress: 92%
Progress: 97%
Progress: 100%
Phase: Program
Progress: 0%
Progress: 1%
Progress: 2%
Progress: 3%
Progress: 4%
Progress: 5%
Progress: 6%
Progress: 7%
Progress: 8%
Progress: 9%
Progress: 10%
Progress: 11%
Progress: 12%
Progress: 13%
Progress: 14%
Progress: 15%
Progress: 16%
Progress: 17%
Progress: 18%
Progress: 19%
Progress: 20%
Progress: 21%
Progress: 22%
Progress: 23%
Progress: 24%
Progress: 25%
Progress: 26%
Progress: 27%
Progress: 28%
Progress: 29%
Progress: 30%
Progress: 31%
Progress: 32%
Progress: 33%
Progress: 34%
Progress: 35%
Progress: 36%
Progress: 37%
Progress: 38%
Progress: 39%
Progress: 40%
Progress: 41%
Progress: 42%
Progress: 43%
Progress: 44%
Progress: 45%
Progress: 46%
Progress: 47%
Progress: 48%
Progress: 49%
Progress: 50%
Progress: 51%
Progress: 52%
Progress: 53%
Progress: 54%
Progress: 55%
Progress: 56%
Progress: 57%
Progress: 58%
Progress: 59%
Progress: 60%
Progress: 61%
Progress: 62%
Progress: 63%
Progress: 64%
Progress: 65%
Progress: 66%
Progress: 67%
Progress: 68%
Progress: 69%
Progress: 70%
Progress: 71%
Progress: 72%
Progress: 73%
Progress: 74%
Progress: 75%
Progress: 76%
Progress: 77%
Progress: 78%
Progress: 79%
Progress: 80%
Progress: 81%
Progress: 82%
Progress: 83%
Progress: 84%
Progress: 85%
Progress: 86%
Progress: 87%
Progress: 88%
Progress: 89%
Progress: 90%
Progress: 91%
Progress: 92%
Progress: 93%
Progress: 94%
Progress: 95%
Progress: 96%
Progress: 97%
Progress: 98%
Progress: 99%
Progress: 100%
Phase: Cleanup
Problem seemed to be tied to Read Out Protection on the MCU. Removed that with STM32CubeProgrammer.
