Hello, guys!
Please, tell me, what it means?
What's wrong?
Here is the tune:
https://rusefi.com/online/view.php?msq=496
I have this error with versions of the software released after mach, 10, 2021
What does startup pin state error mean
- image.png (128.12 KiB) Viewed 4916 times
Re: What does XXX error mean
firmware validates expected state of hardware in terms of electric pull down or pull up
looks like on your board there is no pull in the expected direction so firmware refuses to operate in an unsafe setup
i should make error message a bit more clear
Ok, thank you!
But why don't I have this message with previous versions of the software?
For example, posted in December, 18, 2021?
And how to fix this error?
- Slack: dbh97
Re: What does startup pin state error mean
I'm not sure why it shows this error if ETB is disabled, and I don't think it is supposed to, but I think you can fix it by going to "Full Pinout 1/3" in the "Controller" menu and set the ETB pins to "NONE".
