m102 2.3 8v mercedes E190 PROTEUS
subzero
Post by subzero »
i just finished building rusefi proteus for my car just a question,proteus can support 12 volt logic level from hall sensor,my hall a=sensor denso hondamatic works with 12 volts and outpouts 12 volt square signal,is good to go or i will fry the ecu?
Re: m102 2.3 8v mercedes E190 PROTEUS
Yes proteus support +12 digital inputs
subzero
Post by subzero »
thank you andrey :)
subzero
Post by subzero »
placed 62 -2 triggerpulley and hall sensor
subzero
Post by subzero »
just a question rusefi dont have squirts per cycle?
on speeduino used 2 squirts ,on 4 squirts i have very rich idle
subzero wrote:
Mon May 23, 2022 6:57 pm
can you post your tune at rusefi.com/online?
MHTSOS
Github Username: MHTSOSVOODOO
Slack: Dimitri C
Post by MHTSOS »
This sounds like 2 squirts per cycle = batch injection.
4 squirts per cycle = simultaneous injection
and 1 squirt per cycle would be sequential injection.
How are your injectors wired in?
