MicroRusEFI and VR input / VSS
Posted: Sun Nov 01, 2020 8:38 pm
by Gepro
Hello,
I am planning on using an external dual VR conditionner for my MicroRusEFI. Like I do with my megasquirt.
I take a look before, and there is 5v supply on the board and a lot of analog input.
But... When I take a look at the MicroRusEFI, it's impossible to change the 25 or 45 by another analog input, like the frankenso.
Is it a software limit or a hardware limit ?
And there is the same problem with the vehicule speed sensor. Why can't I use another input that 25 or 45 ? What is wrong with the others "AN volt" ? Does the frankenso have better analog input ?!
Sorry if my question is stupid, I am not an engineer.
I can use the VR conditioner before the 25 and 45 input, I don't see problems here, but I would like to know the speed of my vehicule without using an external canbus sensor
Thanks,
Sincerely,
Re: MicroRusEFI and VR input / VSS
Posted: Sun Nov 01, 2020 8:50 pm
That's a usability improvement of rusefi_microrusefi.ini file - at the moment options are very limited to make things simpler for more normal installations. The hardware and ECU firmware have enough flexibility to run at least some of this.
For custom configurations like yours you would have to use rusefi.ini file from "default" bundle but you would have to become a bit of an engineer to figure out what goes where since with "default" file there would be no nice pin names.
I can change rusefi_microrusefi.ini to make it juuuuuust a bit less locked, let me think about it a bit later
Posted: Sun Nov 01, 2020 9:13 pm
by Gepro
Thanks a lot !!
I am happy to know it's a software limit.
I haven't my MicroRusEFI, and I will take a look later for VSS.
I also have a fuel pressure sensor and knock sensor that I only want for logging, it looks possible
The MicroRusEFI is small but have a lot of possibility. <3 <3
Sincerely,
Posted: Sun Nov 01, 2020 9:15 pm
by mck1117
Gepro wrote: ↑Sun Nov 01, 2020 9:13 pm
Yes, fuel pressure is supported, with automatic fuel pressure compensation coming soon!
<3
Posted: Sun Jul 18, 2021 12:21 pm
by JRD McLAREN
can I use any Analog input for VSS please .. ??
- mre_vss.png (86.55 KiB) Viewed 14209 times
..or can anybody tell me, what need to be changed in rusefi_mre_f4.ini file, to "unlock" AN inputs in this dialog ..
... I can test it ...
Posted: Sun Jul 18, 2021 8:43 pm
Need help with this - please make custom .ini file to confirm what pins would work
once you confirm which pins work I would enable see
https://github.com/rusefi/rusefi/issues/2984
Posted: Tue Sep 28, 2021 7:02 pm
by JRD McLAREN
so I have some time today...
Wired VSS HALL sensor to AT4 input ...
It works on hardware side ... (tested as AC switch)
but doing nothing ...
Config / tune is ONLINE
but I'm not shure, if is ini file modified corectly ..
Posted: Tue Sep 28, 2021 7:09 pm
by JRD McLAREN
Log file ...
Posted: Tue Sep 28, 2021 7:27 pm
please provide more context. what .ini change is needed why?
Posted: Tue Sep 28, 2021 7:42 pm
by JRD McLAREN
line 497... vehicleSpeedSensorInputPin
..it must be the same as line 498 clutchUpPin ... ??
Posted: Tue Sep 28, 2021 7:47 pm
please explain what is the context using words.. is this about some stm32 pin? is this about some MRE pin? what is it? what made you want to change file? maybe you want to propose mre yaml file change?
at the moment it looks like major research if what you are trying to do is needed and i am not sure when i would have time to reverse engineer your proposal
Posted: Tue Sep 28, 2021 7:52 pm
by JRD McLAREN
OK... start here ..
https://rusefi.com/forum/viewtopic.php?p=41596#p41596
I'm try to "unlock" AN inputs for VSS...
...try to edit rusefi_mre_f4.ini file
cause MRE has only "25 - Hall Cam" and "45 - VR/Hall Crank" fields ...
but I'm not sure, if is the right way to do this ..
Posted: Tue Sep 28, 2021 7:57 pm
too vague. you did not mention one pin. i am asking to mention ONE SPECIFIC pin, i am not unavailable to discuss all pins generically
Posted: Tue Sep 28, 2021 8:04 pm
by JRD McLAREN
OK ..
I have connected "22 - AN temp 4" .. I have no idea which pin it is on MCU ..
(can we talk about this on slack ..?)
Posted: Tue Sep 28, 2021 8:26 pm
Just made
https://github.com/rusefi/rusefi/commit/9c17dc1dfc3e4924fae8e18fe3ebce5990831a5a change
Please try new snapshot in about 20 minutes from now it would maybe have useful changes in .ini file
Posted: Tue Sep 28, 2021 9:09 pm
by JRD McLAREN
...it's 11.00 PM ..
I will test it tomorrow
Posted: Wed Sep 29, 2021 2:34 pm
by JRD McLAREN
it's working ...
Posted: Wed Sep 29, 2021 2:46 pm
Please use
https://rusefi.com/online for logs
Please do me a favor and delete attached logs from both message. My preference is not to edit your messages but also not to have logs attached to forum
It has to be
Posted: Wed Sep 29, 2021 3:15 pm
by JRD McLAREN
Ok. ..
I'm mean, the ONLINE is for tunes only ..
Posted: Wed Sep 29, 2021 3:22 pm
JRD McLAREN wrote: ↑Wed Sep 29, 2021 3:15 pm
Ok. ..
I mean, the ONLINE is for tunes only ..
This is not true.
- image.png (33.12 KiB) Viewed 13824 times
Posted: Sun Dec 26, 2021 10:22 pm
by JRD McLAREN
