Proteus using spare ign outputs
Posted: Sun Apr 17, 2022 12:15 pm
by kneelo
I have used up all the low side outputs so want to use a spare ign output to drive a relay.
Will this work and do these function as high side outputs?
Re: Proteus using spare ign outputs
Posted: Mon Apr 18, 2022 4:02 am
by kneelo
Just realised these are logic level outputs so hence the reason it doesnt work!
Posted: Mon Apr 18, 2022 5:19 pm
by Simon@FutureProof
One of the highside outputs should be able to do it though.
Due to some quirks of the setup we have a highside driving a solid state relay on the dirft car.
Posted: Mon Apr 18, 2022 6:39 pm
i think key idea is that we have two kinds: some high current high and some lower current ones
Posted: Mon Apr 18, 2022 11:56 pm
Regardless of current the 5v may not be quite enough to get a relay to activate.
It's normally enough to keep one open once it has moved but not to get it to start moving.
I guess the question is, what are you after an extra relay for?
Is there another way it could be handled?
I am also curious how you have run out of 16 lowsides?
Posted: Tue Apr 19, 2022 11:26 am
by kneelo
Its a relay to power the WBO2 sensor heater.
The existing outputs are used for
6 x injectors
2 x vvt solenoids
2 x fans
main relay
starter relay
smart alt control
intake manifold solenoid
fuel pump
check engine light
I could probably repurpose the check engine or consolidate the fans i guess
Posted: Tue Apr 19, 2022 1:02 pm
by hugovw1976
You can add external transistor (BC337) to control the 12v relay.
Posted: Wed Apr 20, 2022 5:28 pm
by puff
can a small mosfet be used instead of BC337 in this case? (with a flyback diode across the coil)
Posted: Wed Apr 20, 2022 5:33 pm
by mck1117
puff wrote: ↑Wed Apr 20, 2022 5:28 pm
of course
Posted: Wed Apr 20, 2022 8:48 pm
by hugovw1976
puff wrote:can a small mosfet be used instead of BC337 in this case? (with a flyback diode across the coil)
Yes, no problem
Enviado desde mi SM-G988U1 mediante Tapatalk
