Disabling UART TX pin
95_Octane
Post by 95_Octane »
Hey guys I need some help here how to I disable primary UART I need pin PC10 and TS is telling me it’s being used by primary UART TX
Thanks in advance.
Re: Disabling UART TX pin
C'mon, no mention of the board type? :(
95_Octane
Post by 95_Octane »
It’s a custom F4 board Image
95_Octane wrote:
Tue Nov 29, 2022 12:51 am
Primary UART is a compile-time option, you would need a custom firmware.
95_Octane
Post by 95_Octane »
Ok thank you, those pins are RX PC10 and TX PC11 correct?
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
95_Octane wrote:
Tue Nov 29, 2022 1:07 am
This depends on what FW you are using for your custom HW:
$ grep EFI_CONSOLE_TX_BRAIN -R config/
config/boards/prometheus/efifeatures.h:#undef EFI_CONSOLE_TX_BRAIN_PIN
config/boards/prometheus/efifeatures.h:#define EFI_CONSOLE_TX_BRAIN_PIN Gpio::A0
config/boards/hellen/hellen-common144.mk:PRIMARY_COMMUNICATION_PORT_USART2=-DEFI_CONSOLE_TX_BRAIN_PIN=Gpio::D6 -DEFI_CONSOLE_RX_BRAIN_PIN=Gpio::D5 -DTS_PRIMARY_PORT=UARTD2 -DSTM32_UART_USE_USART2=1
config/boards/skeleton/efifeatures.h:#define EFI_CONSOLE_TX_BRAIN_PIN Gpio::C10
config/boards/microrusefi/board.mk:DDEFS += -DEFI_CONSOLE_TX_BRAIN_PIN=Gpio::B10 -DEFI_CONSOLE_RX_BRAIN_PIN=Gpio::B11
config/boards/kinetis/efifeatures.h:#define EFI_CONSOLE_TX_BRAIN_PIN Gpio::A10
config/boards/proteus/board.mk:	DDEFS += -DEFI_CONSOLE_TX_BRAIN_PIN=Gpio::D5 -DEFI_CONSOLE_RX_BRAIN_PIN=Gpio::D6
config/stm32f7ems/efifeatures.h:#undef EFI_CONSOLE_TX_BRAIN_PIN
config/stm32f7ems/efifeatures.h:#define EFI_CONSOLE_TX_BRAIN_PIN Gpio::D8
config/stm32f4ems/efifeatures.h:#ifndef EFI_CONSOLE_TX_BRAIN_PIN
config/stm32f4ems/efifeatures.h:#define EFI_CONSOLE_TX_BRAIN_PIN Gpio::C10
95_Octane
Post by 95_Octane »
This is the one I downloaded
