[rusEfi] Two stroke Efi (#14)
Re: Two stroke Efi
I´m waiting for parts, maybe +15 days.
Re: Two stroke Efi
what it is?Number-One wrote:Arrived
Re: Two stroke Efi
Smd resistores and capacitores.
Re: Two stroke Efi
oh , right . just never saw packing for SMD.
Re: Two stroke Efi
Jared, do we have the q401 resistor channel side flip documented somewhere? In case Filipe would be using q401 for ignition control?
Re: Two stroke Efi
I don't' think I fully understand the question, perhaps that's because I'm assuming my cryptic schematic is clear
What I was trying to indicate, is that normally R402 is 0 ohms, and R401 is not populated. Then if you need that funky ignition circuit which was found on at least one engine setup, you would populate R402 with a 100 ohm 1 watt thru hole resistor, and R401 with a 75 ohm 1/2 watt thru hole resistor. If you have any more questions feel free to ask.
Re: Two stroke Efi
The reason to consider this trick here is that it's easier to buy fewer kinds of different parts - since only one coil is needed this would eliminate the need in TC4427
![Image](http://i.imgur.com/btnlRdZ.png)
Re: Two stroke Efi
One more step, still waiting for parts.
![Image](https://dl.dropboxusercontent.com/u/33323872/Motas/Sachs/Minha/Motor/20141202_210409.jpg)
![Image](https://dl.dropboxusercontent.com/u/33323872/Motas/Sachs/Minha/Motor/20141202_210326.jpg)
![Image](https://dl.dropboxusercontent.com/u/33323872/Motas/Sachs/Minha/Motor/20141202_210331.jpg)
one week more to be finished![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: Two stroke Efi
First video
Re: Two stroke Efi
You could probably engage the starter under normal use, and call that a hybrid
It's cranking right along in that video. I'd bet it slows down once you have compression.
Does this mean you can attempt a capture of the crank signal pattern? I'm not sure how far along you have gotten the soldering.
Re: Two stroke Efi
This's to check the starter motor only. The engine it's without cilinder head, need adjust head compression to this piston.
Re: Two stroke Efi
Re: Two stroke Efi
Engine closed and working with carburator. Next step, fit itb.
Re: Two stroke Efi
it's great sounds .
Re: Two stroke Efi
I've added some info regarding triggerinfo command on the wiki: http://rusefi.com/wiki/index.php?title=Manual:Software:Trigger#Troubleshooting_trigger_input
![Image](http://i.imgur.com/zxXvhd5.png)
Re: Two stroke Efi
Also a new wiki page: http://rusefi.com/wiki/index.php?title=Manual:Software_Temperature_Sensors
Re: Two stroke Efi
I've changed the input pin for you so that you do not need to re-solder anything. Please update to latest version of the firmware and execute 'set_engine_type 29' to re-apply your configuration.
Once you do that, your triggerinfo command would start showing PA5 as your input pin:
![Image](http://i.imgur.com/rYeVlMo.png)
I believe you should be able to change the input pin via TunerStudio also.
Re: Two stroke Efi
Thanks, tomorow morning i will test it. ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: Two stroke Efi
VR input works!
Now I need to count how many small teeth I have after the wide tooth.
![Image](http://i.imgur.com/aQfAEqw.png)
Re: Two stroke Efi
Looks like we are getting closer ![Smile :)](./images/smilies/icon_e_smile.gif)
What is your plan for sensors? What are all sensors you have and what are you going to use for engine load - TPS/MAF/MAP?
Re: Two stroke Efi
Injector is pulsing ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: Two stroke Efi
russian wrote:Looks like we are getting closer
We can trie map or tps.
Re: Two stroke Efi
if you do a tps setup, could you please record a screencast? or just a brief tutorial?
Re: Two stroke Efi
Maybe i will do it by tps, because my engine only have one cylinder and the map signal isn't constante, it´s like a wave. I think will be hard tune it with map sensor.puff wrote:if you do a tps setup, could you please record a screencast? or just a brief tutorial?
Re: Two stroke Efi
Wait a second, this is taken care of! You do not need to worry about the wave.Number-One wrote:because my engine only have one cylinder and the map signal isn't constante, it´s like a wave.
It is also a wave for a 4 cylinder, that's why we have MAP sampling start angle and MAP sampling window angle, and then we average the values within that window. I guess the same would apply to your one-cylinder same exact way as we average a piece of 1st cylinder wave.
Re: Two stroke Efi
russian wrote:Wait a second, this is taken care of! You do not need to worry about the wave.Number-One wrote:because my engine only have one cylinder and the map signal isn't constante, it´s like a wave.
Re: Two stroke Efi
Working.
Working.
Re: Two stroke Efi (#14)
Hooray, first rusEfi two-stroke ![Smile :)](./images/smilies/icon_e_smile.gif)
Congratulations and welcome to the club!!!
