Hello from Nebraska
toofast
Hello from Nebraska
Post by toofast »
I'm a boilermaker currently living in Omaha Nebraska. I have been playing with arduino's and megasquirt for about 5 years now. I wanted a new challenge and was tired of hearing how good megasquirt is. Meanwhile I'm having to modify there hardware in order to run low impedance injectors. Not to mention they are charging way too much for there hardware considering the amount of effort it takes to get decent results.
My current project is a 2000 chevy s10. Im in the process of swapping a 01 5.3l with a 4l80e. Now for the questions. Would the CAN sniffer work in between the ecu and the dash/bcm to help reverse engineer the communications? I would like to keep the stock gauges. Can the unused injector drivers be used to control the transmission? I've been reading up on how the 4l80e works and I think with a little help I can at least get rudimentary control with your ecm.
A picture of an 81 camaro when we were wiring up the ms3x.
Re: Hello from Nebraska
Welcome!
toofast wrote:Would the CAN sniffer work in between the ecu and the dash/bcm to help reverse engineer the communications? I would like to keep the stock gauges. Can the unused injector drivers be used to control the transmission?
there is a custom firmware for sniffing only - http://rusefi.com/wiki/index.php?title=Manual:Hardware:CAN_sniffer once you know the messages you do not need it anymore. I wonder if the format was decoded by someone on the internet already since chevy?
sure the unused stuff could be used for anything, as long as you would have unused drivers. worst case scenario an external board could be added for more low-side chips
