Posts: 14376 Joined: Wed Aug 28, 2013 1:28 am
Post
by AndreyB » Wed Jun 17, 2015 9:19 pm
Tambralinga wrote: If my hall sensor input primary input channel PC6 and secondary input channel PA5.
I can setting speed sensor PC6 or PA5?
No.
If you are using PC6 and PA5 for shaft position sensors, you need to use something else for VSS. PA8 for example is one of the options, but you would need to wire the signal through op-amp, same way as shaft sensors are wired.
Tambralinga
donator
Posts: 174 Joined: Wed Jun 18, 2014 8:36 am
Post
by Tambralinga » Sun Aug 30, 2015 6:02 pm
CLT GPIO PC3
Low temp 20
Resistor 2500
middel Temp 23.9
resistor 2080
Hi temp 80
resistor 300
IAT GPIO PA1
Low temp 8.9
Resistor 7000
middel Temp 30.6
resistor 1930
Hi temp 63
resistor 560
Crank coolant temp
Coolant Correction
-18 160
-7 150
4 135
16 125
27 116
38 108
54 102
71 100
TPS PC1
CLT PC3
IAT PA1
MAP PA4
ARF PC4
Fan PE0
Pump PC13
FSIO PE1
Injection Pin1 PB9
Injection Pin2 PB8
Injection Pin3 PE3
Injection Pin4 PE5
Ignition Pin1 PE14
Ignition Pin2 NONE
Ignition Pin3 PE12
Ignition Pin4 NONE
Pls change new config for mitsubishi and Trigger type Miata NA
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Sun Aug 30, 2015 8:12 pm
Tambralinga wrote: Pls change new config
"change" or "new"?
Are we changing existing config or creating a new config so that there are two different Mitsubishi configs?
Tambralinga
donator
Post
by Tambralinga » Mon Aug 31, 2015 12:14 pm
russian wrote: Tambralinga wrote: Pls change new config
"change" or "new"?
Edited from the original.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Sat Sep 26, 2015 1:24 pm
I want to know if the protocal between TS with STM 32 to find out from where?
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Sat Sep 26, 2015 1:25 pm
Tambralinga
donator
Post
by Tambralinga » Sat Oct 10, 2015 1:48 pm
You have protocol for dev console?
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Sat Oct 10, 2015 2:41 pm
Tambralinga wrote: You have protocol for dev console?
dev console is now using the same protocol
Tambralinga
donator
Post
by Tambralinga » Thu May 17, 2018 6:46 am
Hello.
I came back after long gone.
How far is the development?
can use old config?
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Fri May 18, 2018 9:11 am
I don't know knock sensor freq override for mitsubish 4g93
firmware 20180401
set_engine_16 fatail error HW timer
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Sun May 20, 2018 5:26 pm
Not many changes, old engine types should work. CJ125 by
@ is the most important progress recently.
Just added missing parameter to make knock band configurable -
https://github.com/rusefi/rusefi/commit/c757009065f35c2eb3b8047cc31ee160201b21a2
fatail error HW timer can you reproduce this or is this a one time thing? Can you get me steps to reproduce reliably?
Tambralinga
donator
Post
by Tambralinga » Mon May 21, 2018 12:08 pm
error after set_engine_type 16
2018-05-21 19_00: EngineState: confirmation_set_engine_type 16:18
2018-05-21 19_00: EngineState: unknown [set_engine_type 16]
2018-05-21 19_00: EngineState: 140 actions available
2018-05-21 19_00: EngineState: pins: 0 parameters
2018-05-21 19_00: EngineState: help: 0 parameters
2018-05-21 19_00: EngineState: echo: 1 parameters
2018-05-21 19_00: EngineState: ~: 0 parameters
2018-05-21 19_00: EngineState: test: 0 parameters
2018-05-21 19_00: EngineState: hello: 0 parameters
2018-05-21 19_00: EngineState: fatal: 0 parameters
2018-05-21 19_00: EngineState: error: 0 parameters
2018-05-21 19_00: EngineState: threadsinfo: 0 parameters
2018-05-21 19_00: EngineState: reboot: 0 parameters
2018-05-21 19_00: EngineState: readconfig: 0 parameters
2018-05-21 19_00: EngineState: writeconfig: 0 parameters
2018-05-21 19_00: EngineState: burnconfig: 0 parameters
2018-05-21 19_00: EngineState: resetconfig: 0 parameters
2018-05-21 19_00: EngineState: rewriteconfig: 0 parameters
2018-05-21 19_00: EngineState: lcdinfo: 0 parameters
2018-05-21 19_00: EngineState: adcdebug: 1 parameters
2018-05-21 19_00: EngineState: adc: 1 parameters
2018-05-21 19_00: EngineState: egtinfo: 0 parameters
2018-05-21 19_00: EngineState: egtread: 0 parameters
2018-05-21 19_00: EngineState: caninfo: 0 parameters
2018-05-21 19_00: EngineState: chartsize: 1 parameters
2018-05-21 19_00: EngineState: chart: 1 parameters
2018-05-21 19_00: EngineState: reset_engine_chart: 0 parameters
2018-05-21 19_00: EngineState: triggerinfo: 0 parameters
2018-05-21 19_00: EngineState: trigger_shape_info: 0 parameters
2018-05-21 19_00: EngineState: reset_trigger: 0 parameters
2018-05-21 19_00: EngineState: hipinfo: 0 parameters
2018-05-21 19_00: EngineState: set_gain: 1 parameters
2018-05-21 19_00: EngineState: set_band: 1 parameters
2018-05-21 19_00: EngineState: set_hip_prescalerandsdo: 1 parameters
2018-05-21 19_00: EngineState: set_knock_threshold: 1 parameters
2018-05-21 19_00: EngineState: set_max_knock_sub_deg: 1 parameters
2018-05-21 19_00: EngineState: sdinfo: 0 parameters
2018-05-21 19_00: EngineState: mountsd: 0 parameters
2018-05-21 19_00: EngineState: appendtolog: 1 parameters
2018-05-21 19_00: EngineState: umountsd: 0 parameters
2018-05-21 19_00: EngineState: ls: 1 parameters
2018-05-21 19_00: EngineState: del: 1 parameters
2018-05-21 19_00: EngineState: incfilename: 0 parameters
2018-05-21 19_00: EngineState: i2c: 2 parameters
2018-05-21 19_00: EngineState: speedinfo: 0 parameters
2018-05-21 19_00: EngineState: joystickinfo: 0 parameters
2018-05-21 19_00: EngineState: fl: 1 parameters
2018-05-21 19_00: EngineState: warn: 1 parameters
2018-05-21 19_00: EngineState: fuelinfo2: 2 parameters
2018-05-21 19_00: EngineState: fuelinfo: 0 parameters
2018-05-21 19_00: EngineState: set_led_blinking_period: 1 parameters
2018-05-21 19_00: EngineState: status: 0 parameters
2018-05-21 19_00: EngineState: analoginfo: 0 parameters
2018-05-21 19_00: EngineState: set_float: 2 parameters
2018-05-21 19_00: EngineState: set_int: 2 parameters
2018-05-21 19_00: EngineState: set_short: 2 parameters
2018-05-21 19_00: EngineState: set_bit: 3 parameters
2018-05-21 19_00: EngineState: get_float: 1 parameters
2018-05-21 19_00: EngineState: get_int: 1 parameters
2018-05-21 19_00: EngineState: get_short: 1 parameters
2018-05-21 19_00: EngineState: get_bit: 2 parameters
2018-05-21 19_00: EngineState: set_sensor_chart_freq: 1 parameters
2018-05-21 19_00: EngineState: showconfig: 0 parameters
2018-05-21 19_00: EngineState: tempinfo: 0 parameters
2018-05-21 19_00: EngineState: tpsinfo: 0 parameters
2018-05-21 19_00: EngineState: info: 0 parameters
2018-05-21 19_00: EngineState: set_one_coil_ignition: 0 parameters
2018-05-21 19_00: EngineState: set_wasted_spark_ignition: 0 parameters
2018-05-21 19_00: EngineState: set_individual_coils_ignition: 0 parameters
2018-05-21 19_00: EngineState: set_whole_phase_map: 1 parameters
2018-05-21 19_00: EngineState: set_whole_timing_map: 1 parameters
2018-05-21 19_00: EngineState: set_whole_fuel_map: 1 parameters
2018-05-21 19_00: EngineState: set_whole_ve_map: 1 parameters
2018-05-21 19_00: EngineState: set_whole_ign_corr_map: 1 parameters
2018-05-21 19_00: EngineState: set_fuel_map: 3 parameters
2018-05-21 19_00: EngineState: set_timing_map: 3 parameters
2018-05-21 19_00: EngineState: stopengine: 0 parameters
2018-05-21 19_00: EngineState: enable_spi: 1 parameters
2018-05-21 19_00: EngineState: disable_spi: 1 parameters
2018-05-21 19_00: EngineState: enable: 1 parameters
2018-05-21 19_00: EngineState: disable: 1 parameters
2018-05-21 19_00: EngineState: set_toothed_wheel: 2 parameters
2018-05-21 19_00: EngineState: set_flat_injector_lag: 1 parameters
2018-05-21 19_00: EngineState: set_injector_lag: 2 parameters
2018-05-21 19_00: EngineState: set_fan: 2 parameters
2018-05-21 19_00: EngineState: set: 2 parameters
2018-05-21 19_00: EngineState: get: 1 parameters
2018-05-21 19_00: EngineState: showpin: 1 parameters
2018-05-21 19_00: EngineState: set_injection_pin: 2 parameters
2018-05-21 19_00: EngineState: set_ignition_pin: 2 parameters
2018-05-21 19_00: EngineState: set_trigger_input_pin: 2 parameters
2018-05-21 19_00: EngineState: set_trigger_simulator_pin: 2 parameters
2018-05-21 19_00: EngineState: set_egt_cs_pin: 2 parameters
2018-05-21 19_00: EngineState: set_egt_spi: 1 parameters
2018-05-21 19_00: EngineState: set_trigger_simulator_mode: 2 parameters
2018-05-21 19_00: EngineState: set_fuel_pump_pin: 1 parameters
2018-05-21 19_00: EngineState: set_ac_pin: 1 parameters
2018-05-21 19_00: EngineState: set_alternator_pin: 1 parameters
2018-05-21 19_00: EngineState: set_idle_pin: 1 parameters
2018-05-21 19_00: EngineState: set_main_relay_pin: 1 parameters
2018-05-21 19_00: EngineState: set_analog_input_pin: 2 parameters
2018-05-21 19_00: EngineState: set_logic_input_pin: 2 parameters
2018-05-21 19_00: EngineState: set_pot_spi: 1 parameters
2018-05-21 19_00: EngineState: tsinfo: 0 parameters
2018-05-21 19_00: EngineState: reset_ts: 0 parameters
2018-05-21 19_00: EngineState: set_ts_speed: 1 parameters
2018-05-21 19_00: EngineState: test_clt_by_r: 1 parameters
2018-05-21 19_00: EngineState: mapinfo: 0 parameters
2018-05-21 19_00: EngineState: set_fsio_pid_output_pin: 2 parameters
2018-05-21 19_00: EngineState: set_fsio_output_pin: 2 parameters
2018-05-21 19_00: EngineState: set_fsio_output_frequency: 2 parameters
2018-05-21 19_00: EngineState: set_fsio_input_pin: 2 parameters
2018-05-21 19_00: EngineState: set_rpn_expression: 2 parameters
2018-05-21 19_00: EngineState: set_fsio_setting: 2 parameters
2018-05-21 19_00: EngineState: fsioinfo: 0 parameters
2018-05-21 19_00: EngineState: rpn_eval: 1 parameters
2018-05-21 19_00: EngineState: accelinfo: 0 parameters
2018-05-21 19_00: EngineState: binarytest: 0 parameters
2018-05-21 19_00: EngineState: waveinfo: 0 parameters
2018-05-21 19_00: EngineState: set_logic_input_mode: 2 parameters
2018-05-21 19_00: EngineState: injector: 2 parameters
2018-05-21 19_00: EngineState: fuelpumpbench: 0 parameters
2018-05-21 19_00: EngineState: fuelpumpbench2: 1 parameters
2018-05-21 19_00: EngineState: fanbench: 0 parameters
2018-05-21 19_00: EngineState: fanbench2: 1 parameters
2018-05-21 19_00: EngineState: dizzybench: 0 parameters
2018-05-21 19_00: EngineState: milbench: 0 parameters
2018-05-21 19_00: EngineState: fuelbench: 3 parameters
2018-05-21 19_00: EngineState: sparkbench: 3 parameters
2018-05-21 19_00: EngineState: fuelbench2: 5 parameters
2018-05-21 19_00: EngineState: sparkbench2: 5 parameters
2018-05-21 19_00: EngineState: altinfo: 0 parameters
2018-05-21 19_00: EngineState: ethinfo: 0 parameters
2018-05-21 19_00: EngineState: faststat: 0 parameters
2018-05-21 19_00: EngineState: performanceinfo: 0 parameters
2018-05-21 19_00: EngineState: maininfo: 0 parameters
2018-05-21 19_00: EngineState: idleinfo: 0 parameters
2018-05-21 19_00: EngineState: blipidle: 2 parameters
2018-05-21 19_00: EngineState: idlebench: 0 parameters
2018-05-21 19_00: EngineState: reset_accel: 0 parameters
2018-05-21 19_00: EngineState: rpm: 1 parameters
2018-05-21 19_00: EngineState: stop_stimulator_at_index: 1 parameters
2018-05-21 19_00: EngineState: resume_stimulator: 0 parameters
2018-05-21 19_00: EngineState: For more visit http://rusefi.com/wiki/index.php?title=Manual:Software:dev_console_commands
2018-05-21 19_00: EngineState: error: synchronizationPoint @ index 3 expected 2/2/0 got 4/0/0
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Wed May 23, 2018 6:43 am
step 1 erase chip
step 2 program new firmware
error ERROR: CRC header size
EngineState: FATAL error: HW timer state 1
2018-05-23 13_15: CommandQueue: SerialIO started
2018-05-23 13_15: SerialManager: Opening port: COM5
2018-05-23 13_15: EngineState: WARNING: flash CRC failed
2018-05-23 13_15: EngineState: applyNonPersistentConfiguration()
2018-05-23 13_15: EngineState: initializeTriggerShape(TT_ONE_PLUS_ONE/16)
2018-05-23 13_15: EngineState: *** rusEFI (c) Andrey Belomutskiy 2012-2017. All rights reserved.
2018-05-23 13_15: EngineState: rusEFI v20180401@15715
2018-05-23 13_15: EngineState: *** Chibios Kernel: 4.0.3
2018-05-23 13_15: EngineState: *** Compiled: May 20 2018 - 15:55:54
2018-05-23 13_15: EngineState: COMPILER=6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512]
2018-05-23 13_15: EngineState: CORTEX_MAX_KERNEL_PRIORITY=2
2018-05-23 13_15: EngineState: STM32_ADCCLK=21000000
2018-05-23 13_15: EngineState: STM32_TIMCLK1=84000000
2018-05-23 13_15: EngineState: STM32_TIMCLK2=168000000
2018-05-23 13_15: EngineState: STM32_PCLK1=42000000
2018-05-23 13_15: EngineState: STM32_PCLK2=84000000
2018-05-23 13_15: EngineState: PORT_IDLE_THREAD_STACK_SIZE=1024
2018-05-23 13_15: EngineState: CH_DBG_ENABLE_ASSERTS=1
2018-05-23 13_15: EngineState: CH_DBG_SYSTEM_STATE_CHECK=1
2018-05-23 13_15: EngineState: CH_DBG_ENABLE_STACK_CHECK=1
2018-05-23 13_15: EngineState: EFI_WAVE_ANALYZER=1
2018-05-23 13_15: EngineState: EFI_TUNER_STUDIO=1
2018-05-23 13_15: EngineState: EFI_SIGNAL_EXECUTOR_SLEEP=0
2018-05-23 13_15: EngineState: EFI_SIGNAL_EXECUTOR_HW_TIMER=0
2018-05-23 13_15: EngineState: EFI_SHAFT_POSITION_INPUT=1
2018-05-23 13_15: EngineState: EFI_INTERNAL_ADC=1
2018-05-23 13_15: EngineState: led: ERROR status on PD14
2018-05-23 13_15: EngineState: lcd RS on PE7
2018-05-23 13_15: EngineState: lcd E on PE9
2018-05-23 13_15: EngineState: lcd DB4 on PE11
2018-05-23 13_15: EngineState: lcd DB5 on PE13
2018-05-23 13_15: EngineState: lcd DB6 on PE15
2018-05-23 13_15: EngineState: lcd DB7 on PB10
2018-05-23 13_15: EngineState: board test on PB0
2018-05-23 13_15: EngineState: adc input on PA0
2018-05-23 13_15: EngineState: adc input on PA2
2018-05-23 13_15: EngineState: adc input on PC0
2018-05-23 13_15: EngineState: adc input on PC1
2018-05-23 13_15: EngineState: adc input on PC2
2018-05-23 13_15: EngineState: adc input on PC3
2018-05-23 13_15: EngineState: adc input on PC4
2018-05-23 13_15: EngineState: spi CS5 on PD4
2018-05-23 13_15: EngineState: fuel pump relay on PE4
2018-05-23 13_15: EngineState: main relay on PD7
2018-05-23 13_15: EngineState: fan relay on PE5
2018-05-23 13_15: EngineState: CAN TX on PB6
2018-05-23 13_15: EngineState: CAN RX on PB12
2018-05-23 13_15: EngineState: engine chart: Yes
2018-05-23 13_15: EngineState: engine chart size=300
2018-05-23 13_15: EngineState: trigger#1 on PC6
2018-05-23 13_15: EngineState: turnOnTriggerInputPin PC6
2018-05-23 13_15: EngineState: trigger#2 on PA5
2018-05-23 13_15: EngineState: turnOnTriggerInputPin PA5
2018-05-23 13_15: EngineState: SPI clock on PB13
2018-05-23 13_15: EngineState: SPI master out on PB15
2018-05-23 13_15: EngineState: SPI master in on PB14
2018-05-23 13_15: EngineState: SPI clock on PB3
2018-05-23 13_15: EngineState: SPI master out on PB5
2018-05-23 13_15: EngineState: SPI master in on PB4
2018-05-23 13_15: EngineState: hip int/hold on PB11
2018-05-23 13_15: EngineState: hip CS on PB0
2018-05-23 13_15: EngineState: Starting HIP9011/TPIC8101 driver
2018-05-23 13_15: EngineState: joy center on PC8
2018-05-23 13_15: EngineState: joy A on PD10
2018-05-23 13_15: EngineState: joy D on PD11
2018-05-23 13_15: EngineState: i1 on PB9
2018-05-23 13_15: EngineState: i2 on PE2
2018-05-23 13_15: EngineState: i3 on PB8
2018-05-23 13_15: EngineState: i4 on PB7
2018-05-23 13_15: EngineState: c1 on PE14
2018-05-23 13_15: EngineState: c2 on PC7
2018-05-23 13_15: EngineState: c3 on PC9
2018-05-23 13_15: EngineState: c4 on PE10
2018-05-23 13_15: EngineState: injector_1: 1
2018-05-23 13_15: EngineState: injector_2: 1
2018-05-23 13_15: EngineState: injector_3: 1
2018-05-23 13_15: EngineState: injector_4: 1
2018-05-23 13_15: EngineState: led: comm status on PD15
2018-05-23 13_15: EngineState: led: warning status on PD13
2018-05-23 13_15: EngineState: led: running status on PD12
2018-05-23 13_15: EngineState: FATAL error: HW timer state 1
2018-05-23 13_15: EngineState: TS: ERROR: no second byte
2018-05-23 13_15: EngineState: TunerStudio size=356 / total=0 / errors=0 / H=0 / O=0 / P=0 / B=0
2018-05-23 13_15: EngineState: TunerStudio W=0 / C=0 / P=0 / page=0
after set set_engine_type 16
2018-05-23 13_40: EngineState: confirmation_set_engine_type 16:18
2018-05-23 13_40: EngineState: unknown [set_engine_type 16]
2018-05-23 13_40: EngineState: 115 actions available
2018-05-23 13_40: EngineState: pins: 0 parameters
2018-05-23 13_40: EngineState: help: 0 parameters
2018-05-23 13_40: EngineState: echo: 1 parameters
2018-05-23 13_40: EngineState: ~: 0 parameters
2018-05-23 13_40: EngineState: test: 0 parameters
2018-05-23 13_40: EngineState: hello: 0 parameters
2018-05-23 13_40: EngineState: fatal: 0 parameters
2018-05-23 13_40: EngineState: error: 0 parameters
2018-05-23 13_40: EngineState: threadsinfo: 0 parameters
2018-05-23 13_40: EngineState: reboot: 0 parameters
2018-05-23 13_40: EngineState: readconfig: 0 parameters
2018-05-23 13_40: EngineState: writeconfig: 0 parameters
2018-05-23 13_40: EngineState: burnconfig: 0 parameters
2018-05-23 13_40: EngineState: resetconfig: 0 parameters
2018-05-23 13_40: EngineState: rewriteconfig: 0 parameters
2018-05-23 13_40: EngineState: lcdinfo: 0 parameters
2018-05-23 13_40: EngineState: adcdebug: 1 parameters
2018-05-23 13_40: EngineState: adc: 1 parameters
2018-05-23 13_40: EngineState: egtinfo: 0 parameters
2018-05-23 13_40: EngineState: egtread: 0 parameters
2018-05-23 13_40: EngineState: caninfo: 0 parameters
2018-05-23 13_40: EngineState: chartsize: 1 parameters
2018-05-23 13_40: EngineState: chart: 1 parameters
2018-05-23 13_40: EngineState: reset_engine_chart: 0 parameters
2018-05-23 13_40: EngineState: triggerinfo: 0 parameters
2018-05-23 13_40: EngineState: trigger_shape_info: 0 parameters
2018-05-23 13_40: EngineState: reset_trigger: 0 parameters
2018-05-23 13_40: EngineState: hipinfo: 0 parameters
2018-05-23 13_40: EngineState: set_gain: 1 parameters
2018-05-23 13_40: EngineState: set_band: 1 parameters
2018-05-23 13_40: EngineState: set_hip_prescalerandsdo: 1 parameters
2018-05-23 13_40: EngineState: set_knock_threshold: 1 parameters
2018-05-23 13_40: EngineState: set_max_knock_sub_deg: 1 parameters
2018-05-23 13_40: EngineState: sdinfo: 0 parameters
2018-05-23 13_40: EngineState: mountsd: 0 parameters
2018-05-23 13_40: EngineState: appendtolog: 1 parameters
2018-05-23 13_40: EngineState: umountsd: 0 parameters
2018-05-23 13_40: EngineState: ls: 1 parameters
2018-05-23 13_40: EngineState: del: 1 parameters
2018-05-23 13_40: EngineState: incfilename: 0 parameters
2018-05-23 13_40: EngineState: i2c: 2 parameters
2018-05-23 13_40: EngineState: speedinfo: 0 parameters
2018-05-23 13_40: EngineState: joystickinfo: 0 parameters
2018-05-23 13_40: EngineState: fl: 1 parameters
2018-05-23 13_40: EngineState: warn: 1 parameters
2018-05-23 13_40: EngineState: fuelinfo2: 2 parameters
2018-05-23 13_40: EngineState: fuelinfo: 0 parameters
2018-05-23 13_40: EngineState: set_led_blinking_period: 1 parameters
2018-05-23 13_40: EngineState: status: 0 parameters
2018-05-23 13_40: EngineState: analoginfo: 0 parameters
2018-05-23 13_40: EngineState: set_float: 2 parameters
2018-05-23 13_40: EngineState: set_int: 2 parameters
2018-05-23 13_40: EngineState: set_short: 2 parameters
2018-05-23 13_40: EngineState: set_bit: 3 parameters
2018-05-23 13_40: EngineState: get_float: 1 parameters
2018-05-23 13_40: EngineState: get_int: 1 parameters
2018-05-23 13_40: EngineState: get_short: 1 parameters
2018-05-23 13_40: EngineState: get_bit: 2 parameters
2018-05-23 13_40: EngineState: set_sensor_chart_freq: 1 parameters
2018-05-23 13_40: EngineState: showconfig: 0 parameters
2018-05-23 13_40: EngineState: tempinfo: 0 parameters
2018-05-23 13_40: EngineState: tpsinfo: 0 parameters
2018-05-23 13_40: EngineState: info: 0 parameters
2018-05-23 13_40: EngineState: set_one_coil_ignition: 0 parameters
2018-05-23 13_40: EngineState: set_wasted_spark_ignition: 0 parameters
2018-05-23 13_40: EngineState: set_individual_coils_ignition: 0 parameters
2018-05-23 13_40: EngineState: set_whole_phase_map: 1 parameters
2018-05-23 13_40: EngineState: set_whole_timing_map: 1 parameters
2018-05-23 13_40: EngineState: set_whole_fuel_map: 1 parameters
2018-05-23 13_40: EngineState: set_whole_ve_map: 1 parameters
2018-05-23 13_40: EngineState: set_whole_ign_corr_map: 1 parameters
2018-05-23 13_40: EngineState: set_fuel_map: 3 parameters
2018-05-23 13_40: EngineState: set_timing_map: 3 parameters
2018-05-23 13_40: EngineState: stopengine: 0 parameters
2018-05-23 13_40: EngineState: enable_spi: 1 parameters
2018-05-23 13_40: EngineState: disable_spi: 1 parameters
2018-05-23 13_40: EngineState: enable: 1 parameters
2018-05-23 13_40: EngineState: disable: 1 parameters
2018-05-23 13_40: EngineState: set_toothed_wheel: 2 parameters
2018-05-23 13_40: EngineState: set_flat_injector_lag: 1 parameters
2018-05-23 13_40: EngineState: set_injector_lag: 2 parameters
2018-05-23 13_40: EngineState: set_fan: 2 parameters
2018-05-23 13_40: EngineState: set: 2 parameters
2018-05-23 13_40: EngineState: get: 1 parameters
2018-05-23 13_40: EngineState: showpin: 1 parameters
2018-05-23 13_40: EngineState: set_injection_pin: 2 parameters
2018-05-23 13_40: EngineState: set_ignition_pin: 2 parameters
2018-05-23 13_40: EngineState: set_trigger_input_pin: 2 parameters
2018-05-23 13_40: EngineState: set_trigger_simulator_pin: 2 parameters
2018-05-23 13_40: EngineState: set_egt_cs_pin: 2 parameters
2018-05-23 13_40: EngineState: set_egt_spi: 1 parameters
2018-05-23 13_40: EngineState: set_trigger_simulator_mode: 2 parameters
2018-05-23 13_40: EngineState: set_fuel_pump_pin: 1 parameters
2018-05-23 13_40: EngineState: set_ac_pin: 1 parameters
2018-05-23 13_40: EngineState: set_alternator_pin: 1 parameters
2018-05-23 13_40: EngineState: set_idle_pin: 1 parameters
2018-05-23 13_40: EngineState: set_main_relay_pin: 1 parameters
2018-05-23 13_40: EngineState: set_analog_input_pin: 2 parameters
2018-05-23 13_40: EngineState: set_logic_input_pin: 2 parameters
2018-05-23 13_40: EngineState: set_pot_spi: 1 parameters
2018-05-23 13_40: EngineState: tsinfo: 0 parameters
2018-05-23 13_40: EngineState: reset_ts: 0 parameters
2018-05-23 13_40: EngineState: set_ts_speed: 1 parameters
2018-05-23 13_40: EngineState: binarytest: 0 parameters
2018-05-23 13_40: EngineState: injector: 2 parameters
2018-05-23 13_40: EngineState: fuelpumpbench: 0 parameters
2018-05-23 13_40: EngineState: fuelpumpbench2: 1 parameters
2018-05-23 13_40: EngineState: fanbench: 0 parameters
2018-05-23 13_40: EngineState: fanbench2: 1 parameters
2018-05-23 13_40: EngineState: dizzybench: 0 parameters
2018-05-23 13_40: EngineState: milbench: 0 parameters
2018-05-23 13_40: EngineState: fuelbench: 3 parameters
2018-05-23 13_40: EngineState: sparkbench: 3 parameters
2018-05-23 13_40: EngineState: fuelbench2: 5 parameters
2018-05-23 13_40: EngineState: sparkbench2: 5 parameters
2018-05-23 13_40: EngineState: For more visit http://rusefi.com/wiki/index.php?title=Manual:Software:dev_console_commands
2018-05-23 13_40: EngineState: FATAL error: HW timer state 1
after reboot
2018-05-23 13_37: EngineState: FATAL error: HW timer state 1
2018-05-23 13_37: EngineState: confirmation_set date 1527082629:19
2018-05-23 13_37: CommandQueue: Took 3 attempts
2018-05-23 13_37: EngineState: confirmation_ls /:4
2018-05-23 13_37: EngineState: Error: No File system is mounted
2018-05-23 13_37: EngineState: confirmation_set date 1527082646:19
Tambralinga on Thu May 24, 2018 9:42 pm, edited 1 time in total.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Wed May 23, 2018 5:08 pm
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Fri May 25, 2018 2:25 am
A smaller problem is unknown [set_engine_type 16]
there needs to be a space after "set" now
set engine_type 16
Post
by AndreyB » Fri May 25, 2018 2:38 am
but the bigger problem is the thing you are reporting, let me try reproducing
Tambralinga
donator
Post
by Tambralinga » Fri May 25, 2018 8:57 am
russian wrote: ↑ Fri May 25, 2018 2:38 am
first step install firmware have error CRC.
EngineState: ERROR: CRC header size
I can not solve this proplem.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Sun May 27, 2018 8:19 pm
The problem that from pb1 ่junp to ground.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Mon May 28, 2018 4:01 pm
help me
The right values for first start engine.
what default standard for mitsubishi?
old config 2015
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Tue May 29, 2018 2:20 pm
Tambralinga wrote: ↑ Mon May 28, 2018 4:01 pm
help me
I do not understand the question. Do you want all 30 values for all these three screens? what seems to be problem exactly what is different with your other cars?
Tambralinga
donator
Post
by Tambralinga » Sat Jun 09, 2018 4:09 pm
I can start the engine with the value.
trigger type= miata NA
trigger angle offset =0
advance deg = 15
charge =70
it ok for mitsubishi
if connect afr LSU 4.2 need to use cj125 ?
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Mon Jun 11, 2018 4:16 pm
I don't know how did it happen WARNING
2018-06-11 23_04: EngineState: WARNING: interpolate: Same x1 and x2 in interpolate: 0.00/0.00
2018-06-11 23_05: EngineState: WARNING: interpolate: Same x1 and x2 in interpolate: 0.00/0.00
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Fri Jun 22, 2018 3:12 pm
new firmwaer ok no warning
Skype : shiva-p
+66 8 5357 5159
Tambralinga
donator
Post
by Tambralinga » Wed Jul 04, 2018 12:05 pm
Can be used normally, but there are problems warning TPS
2018-07-04 19_02: EngineState: WARNING: TPS too low: 0.03
2018-07-04 19_02: EngineState: WARNING: TPS too low: 0.15
2018-07-04 19_02: EngineState: WARNING: TPS too low: -0.03
tpsinfo
2018-07-04 19_03: EngineState: confirmation_tpsinfo:7
2018-07-04 19_03: EngineState: tps min (closed) 126/max (full) 761 v=0.73 @PC1
2018-07-04 19_03: EngineState: current 10bit=126 value=0.00 rate=0.00
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Mon Jul 09, 2018 9:32 pm
Analog Input Settings -> "TPS low value detection threshold" you probably want it at zero or -3 maybe?
Tambralinga
donator
Post
by Tambralinga » Tue Jul 10, 2018 5:42 pm
russian wrote: ↑ Mon Jul 09, 2018 9:32 pm
What should be used?
Skype : shiva-p
+66 8 5357 5159
Post
by AndreyB » Sun Jul 22, 2018 3:45 pm
Latest project file now contains some explanation
tpsErrorDetectionTooLow = "TPS error detection, what TPS % value is unrealistically low"
tpsErrorDetectionTooHigh = "TPS error detection, what TPS % value is unrealistically high"
Default values are -5% for tpsErrorDetectionTooLow and 105% for tpsErrorDetectionTooHigh or something like that.
