[help needed] Honda OBD1 CKP/CYP/TDC simulate signals
JOELINO
Post by JOELINO »
Hello Everyone.
I repaired a P06 Honda Ecu but i can't do bench test because i have problems to simulate the CKP, CYP and TDC signals from the motor, do you have some recomendation for Bench test the ECU?
I'll apreciate any kind ok help.
Regards.
Re: Honda OBD1 CKP/CYP/TDC simulate signals
those are probably variable reluctance sensors those are not trivial to simulate.
Post by stefanst »
The Jimstim can "emulate" something similar to a VR output- it simply runs a square-wave signal through a capacitor which creates a 0-crossing similar to what a VR output looks like. It's crude, but MAY work for you. No idea if your specific trigger configuration is included.
http://www.jbperf.com/JimStim/JimStim_v2_0_Wheel_Simulator_Setup.html#tach
