Hello from central NJ
Hello from Central New Jersey in USA My Name is Javier I have a 1985 Toyota corolla GTS with a black top 20 valve 4AGE.
Re: Hello from central NJ
Hi ...
Welcome ...
Welcome ...
Oh RWD Corolla
Where in central NJ are you?
What are your plans?
Welcome to the fun discovery that is rusefi
Welcome and good to hear from you.
Have you found the wiki? Just in case you have not here's a link you might be interested in. http://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_board
stefanst wrote:Where in central NJ are you?
I'm in Middlesex county
I am interested in the FRankenso, I would like to get the un assembled kit & put one together
I have read through the wiki's several times & decided to start posting my project to get some feed back from the community. I am an ASE master tech with 14 years of experience, also I have been racing cars for 18 years.Hopefully I can be helpful to the community ,I feel building an ECU would be a great learning experience & I'm very excited to get started.
You need soldering paste & https://www.tindie.com/products/russian/frankenso-04-diy-kit-/
If your position sensors are Hall-effect you can maybe get away without soldering paste. There is that http://rusefi.com/forum/viewtopic.php?f=4&t=425 topic relevant to that.
My crank trigger / cam position sensor is a hall effect inside of my distributor.russian wrote:You need soldering paste & https://www.tindie.com/products/russian/frankenso-04-diy-kit-/
That does remove the requirement of soldering the smallest pitch MAX9926 chip. With Hall Effect sensors I see Frankenso assembled (without secondary USB/TTL chip which you can live without) with only soldering iron and soldering wire.Javidrifter wrote:My crank trigger / cam position sensor is a hall effect inside of my distributor.
ASE master tech, that's cool. I'd bet you can teach us some cool tricks
If you have any questions feel free to ask. If you assemble your board, I suggest starting with the 5V regulator first, as well start with the regulator itself first. It's a large chip on the ground plane. That can be a bugger to get hot enough.
kb1gtt wrote:ASE master tech, that's cool. I'd bet you can teach us some cool tricks![]()
Great thanks again I will let you guys know when I get the kit
Hey guys its been a while, I just ordered my Frankenso DIY kit.
Oh your are only a few miles away from three of us here in NJ
Are you still playing with the 1985 Toyota corolla GTS or do you have a Miata already?
Still messing with the AE86 now I'm fitting a K24 engine from a TSX
