rusEFI simulator - problem
SE-CHelm
Post by SE-CHelm »
Hello,
I`m Carlos and new to the rusEFI and starting to learn and get familiar. I have downloaded the last bundle today and followed the installation accordingly.
To run the virtual simulator I also followed the installation instruction based on my licenced TunerStudio version I have.
The connection between virtual simulator and TunerStudio is successful and the RPM gauge is showing the revolution of 1200 1/min.
The virtual simulator is showing a warning that coild 1 is out of order and not running. Checking by Engine Sniffer, the ignition is missing. Going to change to another engine preset, it depends which one you choose nothing happens or the simutalor stop the conenction to TunerStudio and / or a java message pop off.
Also trying to do any changes by TunerStudion and burning to the board, the virtual simulator shot off the connection.
Some pictures attached ...
Also I have updated the java to ensure all on the computer has the latest version.
Any idea?
Thanks in advance.
BR, Carlos
Re: rusEFI simulator - problem
It's totally a bug, I am seeing this for a while.
But since it's only simulator it's a very low priority sorry.
https://github.com/rusefi/rusefi/issues/4958
SE-CHelm
Post by SE-CHelm »
Hello Andrey,
thanks for your quick reply ... so, there will be no update coming soon on this topic as I understood!?
Thanks,
BR Carlos
Matt has made some changes, please try again.
SE-CHelm
Post by SE-CHelm »
Hello Andrey,
I`m not sure if I need to load a new console or how the changes are linked to try out ... I have run the current installtion and I downloaded a new bundle. The problem still exists, that the ingnition is missing and if changing the presets of the engines, the system stops at least.
Thansk for your help.
BR Carlos
Download a new snapshot rusEFI bundle to get a new version of the simulator and console.
SE-CHelm
Post by SE-CHelm »
Hello mck1117,
ok ... thank your for your reply ... I will try out ...
Thanks,
BR Carlos
SE-CHelm
Post by SE-CHelm »
Hello,
short feedback after reloading the new bundle from yesterday ...
No coil waring anymore and they are working and displayed
now the warning shows no MAP values
Changing the RPM value by entering the new value in the command line is working, but the numbers in ms are not adjusting correctly and it has an impact if you start changing the value from 1200 to 2000 1/s or from the begining from 1200 to 3500 1/s
changing to any other engine preset the console stop running
doing any changes or trying to burn in TunerStudio, the system stops running
BR Carlos
