Pps not reading in Tunerstudio
Re: Pps not reading in Tunerstudio
https://github.com/rusefi/rusefi/wiki/Release-Snapshot-Latest-firmware
https://rusefi.com/online/view.php?msq=1384 says rusEFI 2022.12.08 which seems to be https://github.com/rusefi/rusefi/releases/tag/20221209_release
https://github.com/rusefi/rusefi/wiki/microRusEFI-Manual#software
While that would help explain ETB being disable by PPS issue that does not help us with PPS issue.
At the moment I am still puzzled by the precise zero raw value reading.
Slim804
Github Username: Slim804
Post by Slim804 »
I am as well...
bill
Post by bill »
when you put the voltmeter on the signal wires from the pedal
with 5V and ground supplied to pedal
and move the pedal up and down
what are the voltages output on the wires?
0.5 to 3.5V on one output?
and
4.5 to 0.5 V on the second output?
that is normal for most bosch units
Slim804
Post by Slim804 »
When I put the multimeter on the wires, I'm getting 2.38 on the primary at full throttle and 4.68 on the secondary at full throttle
Are you comfortable detaching PCB from rear cover and poking DMM into corresponding pin to check voltage on pin?
Did you crimp or was it a pigtail?
Slim804
Post by Slim804 »
I did not crimp anything as i wanted to be sure things were working properly before crimping. Im not completely sure what all is involved in that process
huh? how are your wires connector to MRE? please post more pictures
Slim804
Post by Slim804 »
Just twisted together at the moment
Oh now I see that you use MRE pigtail. Still same question - are you comfortable poking into back side of PCB with rear plate removed?
I am kind of running out of ideas :(
Slim804
Post by Slim804 »
I'll take it off and take a look back there
bill
Post by bill »
Slim804 wrote:
Sat Feb 04, 2023 12:18 am
sounds correct.
and around 0.5V on each when the pedal is at idle?
Slim804
Post by Slim804 »
correct
Slim804
Post by Slim804 »
Detached the PCB from rear cover and poked DMM into corresponding pin. Im getting the same voltage at the pins that I was getting at the wires on the pigtail.
i have a feeling that it's time to ship this unit to NJ
Slim804
Post by Slim804 »
Ok,Just let me know when and where to ship. I'm located in Virginia.
Someone else has hit same AV4 drama and we have a theory now, stay tuned!
https://github.com/rusefi/hw_microRusEfi/issues/231
Just removed D7 please PM me your address for return!
If it still does not work type to unbolt from case and poke into pins on the back of the PCB, just be careful. Time to tipple-check if voltage gets all the way to PCB.
mi-hol
Github Username: mi-hol
Post by mi-hol »
@slim804 https://wiki.rusefi.com/HOWTO-M111-on-microRusEFI/#howto-m111-on-microrusefi contains
"Important suggestion: use Honda accelerator pedal position sensor (PPS) in the engine bay not Mercedes pedal position sensor"
no reason is given for this advise but I wonder if that is related to your issue
Best Regards
Michael
Benelli Tornado 900 Tre
Benelli TNT 1130 (rebuilding)
mi-hol wrote:
Sat Mar 11, 2023 10:09 am
Jimmy says Mercedes sensors are pretty unreliable.
mi-hol
Post by mi-hol »
AndreyB wrote:
Sun Mar 12, 2023 5:26 am
none of the many car sensors is actually manufactured by the car companies themselves.
Nearly all parts have a dual supplier (or at least dual factory) strategy in order to avoid supplier lock-in.
In a given car model identical parts are coming from different supplier therefore.
When a part has a failure rate above a given percentage the supplier is reviewed and eventually banned.
Above very broad statement is not really helping to address the root cause.
Root cause is most often something like: sensor from supplier A manufactured in week n of year Y in factory F fails prematurely due to tooling issue.
I was working for a Mercedes supplier some years ago.
Best Regards
Michael
Slim804
Post by Slim804 »
Ok I’ll take a look into that because as of right now I’m still fighting this issue
bombaym111
Github Username: bombaym111
Slack: bombay09
Post by bombaym111 »
Hi you everybody so someone can tell me how can I fix the Pedal position in tuner studio when i choose the right pin like 1er 31 and 2sec 30, not working still ERROR config Bye the way I use the lastes bandle thanks
Rusefi micro 0.6 version
