My personal website logging this build can be found here: https://vfrenjoyer.neocities.org
My goals with this build are to A: Make my bike faster and B: Come up with a reliable turbo setup other people can easily copy while minimizing the time spent with an unridable bike or chasing electrical/tune issues.
I have a 1999 VFR800 and while looking for ways to make it faster that don't involve spending lots of money on a centrifugal supercharger I found an old video of someone who fit a turbo on one. My first steps have been to work out engine management for which I'm currently in the process of setting up a MicrorusEFI 4.8 to plug into the stock ECU harness via a breakout board.
Here's a beautiful block diagram of what I'm attempting:
![Image](https://vfrenjoyer.neocities.org/reallygoodsystemdiagramdotjaypeg.jpg)
This setup is a few days away from starting since during a night of partying hard I somehow sent > 7A of current through the ECU's processor and in the process also killed the TLE8888's VR signal conditioners and I'm waiting for digikey to deliver a replacement. Once I have it reliably running on the microrusEFI my plan is to completely throw away all the hard work I've put into the MRE setup in favor of a much less (installation) labor intensive solution.
RusEFI Hellen Based Plug and Play ECU for the 5th Generation VFR800
![Image](https://vfrenjoyer.neocities.org/1704684207798797.png)
What started as a project to make a breakout board that would let someone use prefabricated molex harnesses to connect to a uaEFI turned into this, which is a a Hellen based ECU that should fit in the stock ECU location and only require the addition of two WBO sensors to install. I'll order the first boards for this once I'm certain the pinout is correct and have the microrusEFI setup sorted out. I'm hoping to start work on the actual turbo install sometime in the early summer, and even without a turbo my bike should make a bit more power once tuned for 93 octane
Things I should have put in the OP but forgot to:
The MRE setup only has the cam sensor connected since there's only one VR input
